Question about Belkin Computers & Internet
How do hook up a wireless laptop to a router and
How do I hook up a wireless laptop to a router and modem
  • 2,263 Answers
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 04, 2010
3 Suggested Answers
shawty-lozzy
  • 151 Answers
SOURCE: I have a belkin wireless router model #f5d9231-4
what do you mean it wont recognize the modem, it should just transfer the data from the modem threw the ethernet cable and convert it to wireless.
Posted on Jul 20, 2009
  • 24 Answers
SOURCE: Connecting My Cable TV Modem To Wireless Router
Yes you should be able to go directly from the modem to the back of a wireless router. You will be able to plug in 4 devices via ethernet and several via wireless depending on which router you have/get. If your looking into getting a router I would recommend LINKSYS. They are the easiest to set up and are the most stable.
Posted on Nov 16, 2009
I cant hook up my d link 150 up to my toshiba sattelite laptop. i have dsl modem and i dont wanna mess it up.
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 09, 2011 | D-Link Wireless N 150 Home Router 4Port...
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
Can you hook up the router without hooking to a tower
Yes the Router can be hooked to a high speed modem like DSL or Cable, that high speed connection would go from the modem to the "internet" port of the router. Now the router would need to be configured if you need wireless, and then a temporary connection to a tower or laptop would be needed.
Aug 10, 2009 | Linksys Wireless-G Broadband Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
I moved my computer - unhooked the modem and wireless router and
Powerdown the PC, router, and modem then start the modem first then the router and finally power-on the computer... That should do it! Hope it helps!
-- Joshua79
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
Dynex Wireless G Router
check the configuration of the router then re-configur the router it
Feb 26, 2009 | Dynex Wireless-G Broadband Router
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Wireless
Hi there!
I want to help you out. I have some questions to ask you first:
1. What brand and model are your wireless router and laptop?
2. Does the laptop have a built-in wireless card or you installed one?
3. If it's has its built-in wireless card, check the wireless switch of the laptop. ICheck if it is on or off (some laptops sometimes has an on/off switch)
4. Check if the wireless light on your router is on (it's sometimes refered to "WLAN")
5. How many wired & wireless computers do you have and their operating system?
Your physical connections are correct. BTW, can you also specify what port from the modem is going to the router? Some routers have 1 port named "Internet or WAN" and 4 ports for "Ethernet." Check if the modem is connected to the "Internet or WAN" port.
May 04, 2008 | Computers & Internet
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
