Question about Sharp PG-A20X Multimedia Projector
I've replaced the bulb and the lamp indicator light still flashes and the lamp does not come on, what else could be wrong?
  • online132 Feb 04, 2010
    I put the original bulb back in the projector and did the timer reset as stipulated in the manual and the lamp is functioning. two things, 1) this probably isn't a good idea as this bulb might be close or over its hour usage rating. 2) it would appear the bulb I bought is faulty.
    P.S. where is the thermal fuse? Might be good to know for future reference
  • Sharp Master
  • 12,061 Answers
The Thermal Fuse may be blown? Check that out.
Posted on Feb 04, 2010
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
Lights flashing
Replace the lamp. The lights flashing will also indicate what is wrong. Watch how they flash. Go to the manufacturers website and they way they are flashing indicates what is wrong (ex. 3 quick flashes, long continuous flashes...etc.) When you change the lamp reset the lamp counter in the menu and clean or replace the dust filters as well.
Jan 11, 2014 | Sanyo PLC-XP200L Projector
Lt 35 flashing glow plug light
In my case, the flashing glow plug indicator is caused by me replacing the stop lights with LED bulbs. Therefore, a cause for this flashing indication could be a blown stop light lamp. The test for this condition is; while the glow plug indicator is flashing, press and release the break pedal. This should stop the indicator from flashing. Check your stoplights. Or add a load resistor to your LED lamps if you have fitted these.
Jun 01, 2012 | Volkswagen Volkswagen Cars & Trucks
I have a Sony KDF-55WF655 and the bulb blew out and I smelled something electrical burning.
3 blinks is indicating that the lamp door cover isnt making contact so the lamp door cover is either attached wrong or the switch is defective.
Oct 26, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
Sharp PG-A20X Multimedia Projector Logo
100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
