Question about Whirlpool Washing Machines
Bought new wfe 10758B front loader - only using cold water so have attached a Y joint and plugged power point in and there is no power. Nothing happens not lights come up or anything. We have pushed every button on front and nothing happens.
  • 129 Answers
Call whirlpool 800# under warranty
Posted on Feb 04, 2010
My maytag neptune washer front loader -the water will not go into washer when it is turned on the serial # is S1101 5853GR and the model 3is MAH8700AWW
First thing I'd check is connections at machine where hoses attach. Shut off water and remove and inspect little screen like filter to trap dirt at machine, to make sure they are not plugged up. Is it happening on both cold and hot?
Jan 26, 2012 | Washing Machines
My daughter has moved into a rental house with a very small Whirlpool front loader. There is no model number or manual, and her email is not working. She would like to wash in cold water as is our...
delicate is typically always only cold
the other 2 are usually warm
if you could reach the faucets where the hoses attach to you could turn off the hot water faucet assuring it would only had cold water going into it
Gene
Aug 11, 2011 | Whirlpool LHW0050PQ Front Load Washer
I bought this front loader no more than 2 years ago-I dont like using hot water to wash my clothes so I always put in on the cold-now no water wants to come through the washer-it only works if my hot water...
Sounds like the water inlet valve is faulty. It the part that attaches to the hot and cold water hoses. It really easy to fix, just disconnect the hoses, pull the washer out and remove the back of the washer to get access to the valve. You can find a replacement by going to your local appliance supply house, or online such as www.repairclinic.com.
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to clean the pump on a Whirlpool front loader Model WFE 1075BD
There are two or 3 quarter inch screws at the bottom of the bottom panel. take those out, then the bottom should swing toward you and be easy to remove. The drain pump is impossible to miss. It'll have a screw type cover with a flat handle. Take it off and there you are.
WARNING: you had better have a wet/dry vac at the ready. there WILL be water waiting to gush out all over you! Best of luck!
Mar 06, 2011 | Whirlpool Washing Machines
Washing machine faberic softner try fills with water when in use.
hot water valve inside unit may be faulty ck it to make sure that it is powering up and then make sure it is operating. the cold and hot valve are one unit on most washers so the unit is replaced as one. if its a front loader than there might be a one way ck valve malfunctioning or the unit keeping intoducing water into the unit even though it is at the level it should be at. top loader then the level sensor is jacked and needs replaced.
Jun 12, 2009 | Frigidaire GLTF1670A Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
May 28, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
