Question about RCA HD61LPW42 61" Rear Projection HDTV
I have a rca projection tv and last couple day my screen went blurry i ran the auto convergence and it was no help it clears up a little right as i turn it off on a scale of ive changed caps anf flyback before please help i can get anyinfo u need
  • RCA Master
  • 8,457 Answers
2 covergence ICS and all it resistors,must replaced to solved convergence.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.
Posted on Feb 04, 2010
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
Tv picture went blurry and looks like two or three images on screen is it possible a bulb burnt out.how do you change
Thats a convergence issue. Press the menu button and scroll to settings then see if the option for convergence and auto convergence is still there or has it disappeared> Then let me know and I will assist you.
Dec 13, 2009 | RCA D52W23 52" HDTV CRT TV
Blurry picture, some color is off
It sound like your tv needs convergence repair. There is a couple of possible causes to this problem on this particular model. One will be a missing voltage due to a loose conection on the fly back transformer, it may cause a fuse to open; it may also be a bad convergence power supply module, or a bad convergence module.
Oct 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi I have a 52" RCA big screen tv that is only 3 years old however we turned it on today and it is showing some red blue and green lines and the picture is blurry
Hello clara7,
This denotes a convergence problem. I would suggest that first you enter the menu of your TV ad try to do an auto converge on your set, if this does not work I would suspect that the convergence ICs have gone bad and need to be replaced. I would suggest that you have a qualified TV repair technician replace the convergence ICs in this set.I hope this helps,Shuttle83http://www.electron-age-technologies-llc.com
Jun 08, 2009 | RCA P52939 52" Rear Projection Television
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Around edge of tv the colors blue/red/green/blurry...
my 52" rca tv just started showing blue red double pictures yesterday...covergence don't show up on the set up menu anymore so i can not do anything..how much will it cost to fix this problem?kodigaston@hotmail.com
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problems
I would suggest the convergence ICs as well as a couple resistors right near the Convergence ICs mst likely. 90 % of the time thats the problem. They are not expensive, if you can solder you can handle it if your careful with your solder and use heat sink compound. The ICs will have a number stamped on them usually STK XXX-XXX on a huge heat sink. The following link will have replacement parts http://electronix.com/ Hope this helps you out
Jan 11, 2008 | Panasonic PT-47X54 47" Rear Projection...
Convergence
Loss of power supply voltage to run convergence circuit.verify w/service literature.Hands-on technical help needed.
Aug 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD61LPW42 61" Rear Projection HDTV Logo
80 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
