Question about Kicker IX1302 Car Audio Amplifier
My friend was hooking up my amp in my car , had the green light lit up , then he was tightening the hot wire to the amp , and nicked the side off the amp with the screw driver , and then there was tiny sparks for a sec. then no light ....... Is this fixable ?
  • 12,061 Answers
IT MAY be just fuses inside the case. You could check... Also check the Reverse Polarity Protection Diode too. But often an event such as this will trash the units power supply and more.
Posted on Feb 04, 2010
On a 1998 chevy cavalier what color wire do i hook the green off my tach to
The green wire from the tach goes to the negative side of the coil or if its an HEI distributor it will connect to the left of the hot wire going. to the distributor.
Apr 01, 2014 | 1998 Chevrolet Cavalier
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
Griddles do not heat.
just fixed mine with info found on hear. If you're a little handy or have someone who is it's a simple fix. Under bottom plate a thermal fuse is connected in black wire under white insulation. I picked one up at radio shack2_bing.gif (http://www.radioshack.com/search/index.jsp?kwCatId=&kw=thermal%20fuse&origkw=thermal%20fuse&sr=1) got the 228 dgree C. I cut insulation and removed. I then cut black wire at connection at each side. I then placed new fuse in line and crimped small connectors on each side. Placed insulation back on and taped up. Screwed back together and it worked fine. Fuse cost $1.69. To think I almost tossed it.
Dec 28, 2009 | Waring WMK300 Professional Belgian Waffle...
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Radio wiring
The factory wiring connector hook-up for the Mustang is:
Radio / Power Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Your best bet is to buy a radio install kit and adapt it to the Mustang connector. Hope this information helps.
Oct 19, 2008 | 2002 Ford F250 Super Duty SuperCab
Wiring for 2500d orion amp
ground wires(heavy black)is connected when the red light lit.so no need check the red hot wire which is connected to battery terminal maybe loose.or theres no power comming in.thre are 2 hotwire in that amp one is red which is the main and yellow or sometimes orange which is the remote on. now if you sure that the power terminals is properly connected,ur speakers is working and input wires are good and still no sound. your amp is probably gone...do not try experimenting the wires or hook up two amp by any means..u might destroy all ur amp. hope this help u....
May 11, 2007 | Orion 2500D Car Audio Amplifier
Help!!!!
Check your ground wire! Relocate it to another place in the car and try to get a heavier ground wire aswell.
Apr 03, 2007 | Sony XM-2200GTX Car Audio Amplifier
Kicker IX1302 Car Audio Amplifier Logo
94 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
