Question about eMachines T6534 PC Desktop
I unpluged the 3 wire for the front the power button and now i dont know were they go help plz
  • joecoolvette
    joecoolvette May 11, 2010
    Computer unplugged from power, computer case open, TOUCH the metal frame of the computer case to relieve your body of Static electricity. The front cover of your computer, is referred to as a Front Panel. The wires on the Front Panel, (Power On button, Power On light, Harddrive activity light, and so on), will connect to an area on the motherboard known as the Front Panel header. There is an abbreviation printed on the motherboard, near this header. JFP1. (Stands for Junction Front Panel 1) See if this Front panel header looks like yours, and if so state it in a comment.http://support.gateway.com/s/MOTHERBD/MS...
    Sergeant:
  • 206 Answers
Schematics for motherboards can be different but most have a series of pins that those plugs are plugged into. Here is a link that will guide you through the process. The pins are labeled POWER/LED/SPEAKER if you look closely. Hope this helps.
Posted on Feb 04, 2010
  • eMachines Master
  • 5,660 Answers
The eMachines T6534 Desktop PC uses an MSI MS-7207 motherboard,
also known as K8NGM2, if my information is correct.
Look at the motherboard, and see if you see MS-7207 in white.
This is MSI Support, and the download page for the Motherboard Manual,
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=224
On this page I would like you to scroll down to where it states - Manual
Under this Manual heading is a large blue bar going across, and it has -
Special Note: in it.
Under that blue bar are some file names listed.
Go down to the second one -
2.0....English....7443KB....E7207v2.0.zip
I would like you to click on the blue - E7207v2.0.zip
On the next page you are to click on the country nearest the one you are in.
I clicked on U.S.
The next thing you will see is a small window, that will come up on the right.
Opening E7207v2.0.zip
Left-click on the empty circle to the left of - Save File.
(Unless there is a green dot in it already)
Now go below and click on OK.
There will be another small window that comes up with a download progress bar.
Watch the download progress bar, and let the file download all the way.
This is a ZIP file.
A ZIP file is used to pass a large amount of information easily, over the internet.
The information is compressed, or 'Zipped'.
You need to Unzip this file.
Where the file will go.
IF, you have your downloads set to save to your My Documents folder,
(Start>My Documents), it will go there.
It may be in a subfolder within My Documents called Downloads.
IF, you Do Not have your downloads set to save to your My Documents folder, this file will go to your desktop screen.
File name is E7207v2.0.
When you see the file name Double-click right on it.
The next thing you will see is the Winzip wizard, and the file name will be listed.
Go up to the left side, and click on - Extract All Files.
In the next small window click on Next, Next, and Finish.
You will now see a window that has the file name, and an Adobe PDF icon next to it. Double-click right on this file name.
You should now be looking at the Motherboard Manual, for your eMachines T6534 - MSI K8NGM2 motherboard.
Left-click on the Maximize icon to the top right of the file, to make it go full screen.
I will lead you through the pages you need, and also state how to hook your Front Panel connectors to the motherboard, in case you cannot download the motherboard manual.
You may be very familiar with PDF documents. In the case that you are not, allow me to show you the easy way of getting to the page you want.
If you are familiar with PDF documents, please disregard the following.
At the top of the PDF file, you will see a box with the page number in it.
This box is to the immediate right of the blue down arrow.
If you Left-click once in the page number box, and type the number you want, then press the Enter key, it will take you right to the exact page you want.
Please go to Page 16.
This page shows you an illustration of your motherboard.
Looking at your computer with the side cover removed, and the back of the computer to your Left, this illustration shows how your motherboard will be oriented inside your computer case.
Processor to the top, Ram Memory slots to the right. Can be a little difficult to view with all of the cables in the way.
At the very bottom right is one of the Front Panel headers on the motherboard.
(Plastic cover on the front of your computer is a Front Panel. You can go to the top of the PDF file, and click on the + sign to enlarge the view. Zoom In. Use the bottom, and right side bars to move the view around.
Connector on a motherboard is referred to as a Header)
It is the JFP1 header. (Junction Front Panel 1)
This is where some of the wires from your Front Panel go.
This header is rectangular shaped, and is placed horizontally.
Right above it is the JFP2 header. (Junction Front Panel 2)
This header is rectangular shaped, and is placed vertically.
Please go to Page 38.
JFP1:
As stated the connector is rectangular shaped. It has 2 rows of pins.
4 across the top, 5 along the bottom.
The top row of pins are numbered evenly, starting from the Left side.
2, 4, 6, 8 and 10.
However there is NO pin 10. Just a blank spot.
The bottom row of pins are numbered odd, starting from the Left side.
1, 3, 5, 7, and 9.
(Back of computer is the Left side)
Pins 2 and 4 are for the Power LED light, if your Power On light has 2 wires. The light that comes on when the computer is turned on.
Pins 6 and 8 are for the Power On switch. (Power On button)
Pins 1 and 3 are for the Harddrive activity light. (HDD)
Pins 5 and 7 are for the Reset switch. (Reset button)
Pin 9 is not used.
JFP2:
As stated the header is rectangular shaped, and is placed vertically. (Right above the JFP1 header)
There are 2 rows of pins.
4 pins coming up the Left side, 3 pins coming up the Right side.
Starting at the Bottom Right side, and coming up.
Pins 1, 3, 5, and 7.
There is No Pin 7, just a blank spot.
Starting on the Left side, coming from the Bottom towards the Top.
Pins, 2, 4, 6, and 8.
Pins 1, 3, and 5 are used for a Power On light that has 3 wires.
Pins 2, 4, 6, and 8 are used for an internal speaker.
  • joecoolvette
    joecoolvette Feb 04, 2010
    To add:
    The wire connectors from your Front Panel should have abbreviations on them.
    The connectors are small, so there isn't much room to designate what they are.
    PW, or PW1, or Pw Sw, is the Power On switch.
    RST, or Rst, is the Reset switch.
    HDD is for the Harddrive activity light. The light that blinks when the harddrive is in use.
    Speaker connectors always have four socket holes.
    Pwr On, or PW ON, is the Power On light.
  • joecoolvette
    joecoolvette Feb 05, 2010
    I see from your rating that I was only Somewhat Helpful.
    May I ask why?
    This information stated from you, will help me to provide solutions.
    Looking at my profile page, you will note that the great majority of my solutions are in the Free section.
    This shows my desire to truly help people.
    Was my information erroneous in the motherboard that the eMachines T6534 uses?
    Was your problem put into the wrong category heading, and your problem does not relate to an eMachines T6534, but another computer altogether?
    Was the information I stated too long, and detailed, and bored you halfway through?
    Would appreciate hearing from you on this matter. Please state in a comment.
Sportsman generator wiring
I know this is an old post, but did you ever find out? Im in the same boat ...i just need the 3 or 4 wire locations behind the switch on the left side, not the harness on the right side ..any help?
Mike
Jan 27, 2013 | Sportsman GEN154 2000 Watt Portable...
I just washed the air filter and after that the compressor is not working i dont know the model number but its a window a/c when i removed the cover there was a wire on the grill, is that wire has to...
Not sure is it does or doesn't relate to the problem. The best way to find out is to replace the wire as you found it. Turn the unit OFF and Unplug it before removing the front again.
Aug 05, 2011 | Samsung AW0503B Air Conditioner
No power,not lighting up when start button pushed. unplugged and replugged several times. no good
is machine lighting up when power point is turned on ?if it isnt then control module is faulty. if it is and your power or start button dont work could b faulty keypad or faulty lid switch.please reply if u need more help
Mar 07, 2010 | Fisher and Paykel IWL12 Top Load Washer
I pulled the 3 wires out of the plug on my 98 isuzu trooper and dont know how thay go back in order can you help me plz
For the 3.2l dohc v6 it is 1,2,3,4,5,6. with the cylinders being numbered from front to back and left to right 1,3,5,right and 2,4,6 left. The left and right side of the vehicle is determined from you setting in the drivers seat For the 2.6l 4cyl it is 1,3,4,2 starting with the right front wire and going in counter clockwise direction, and the cylinders are numbered from front to back 4,3,2,1. hope this helps out
Jul 05, 2009 | 1998 Isuzu Trooper
My imate jama not starting again
replace u r chrger abd check
Jan 14, 2009 | i-mate JAM Pocket PC
Shiki
I am trying to do this from memory as I don't have that model in front of me. turn the printer on. then while the printer is on unplug the power lead (don't turn the printer off first)
hold the OK and cancel buttons and plug the power supply back in. keep holding the buttons until the printer powers off. release the buttons, unplug the power lead and after 10 seconds replug in the lead and and switch the printer on.
this is an NVM reset whcih should clear any "hangs" in the printer.
Let me know!
May 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Power button wiring help
Hello Chub, Your motherboard manual can be downloaded at this link: http://support.asus.com/download/download.aspx?SLanguage=en-us If you go to page 2-31 in the above manual the diagram should show you exactly where your front panel power switch connects to your motherboard. You want to connect it to the position marked below as ?ATX Power Switch?. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 15, 2007 | ASUS A8V Deluxe Motherboard
eMachines T6534 PC Desktop Logo
472 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
