Question about Winter Sports
I can see 2 sets of cross hairs - Winter Sports
  • 425 Answers
All scopes have an adjustment ring, even if it is only to focus it. Use this ring to adjust it and see if your problem will go away. If not then some thing inside has moved from its correct place and will have to be repaired. If it is only a cheap scope, then throw it away, and buy a new one on Ebay, but if it is a top of the range, like Leopold, then it is worth the money to get it professionally repaired. I take all mine optics to a telescope repair person. You work out what you do.
Posted on Feb 04, 2010
What is a cross hair
A crosshair is a part of the aiming device on a gun, as in I have it in the crosshairs
Feb 02, 2017 | Optics
How to french braid hair
Before braiding, brush hair to smooth out any knots or tangles.
Starting at the hairline, gather enough hair from top of head to start a regular braid. Divide hair into three equal sections. Hold right section in right hand, left section in left hand, and middle section between thumb and another finger of either hand.
To begin braid, cross right section over middle section, then repeat this move with left section, smoothing hair down as you go. Pull sections fairly tight; you don't want the braid to be loose and come undone.
Before repeating your cross-over motion with the right section, gather a little bit of additional hair from the head's right side, and add it to this section; now cross this larger portion of hair over the middle section of the braid.
Tip: Make sure that the sections of hair you're adding are roughly equal or the braid will look lopsided.
Gather a small section (of equal size to the one you just gathered) of the remaining hair on the left side of your head up and into the left section and cross that over the middle section.
Tip: Slightly dirty hair has less "slip," making it easier to braid.
Repeat steps 4 and 5, adding hair until you've gathered in all additional hair strands. Finish at the bottom with a regular braid.
Once you reach the bottom of the braid, secure the end with a hair band, wrapping it tightly around the hair.
Videos....
www.youtube.com/watch?v=q6M7WzzYPWI
www.youtube.com/watch?v=ujS0VNOXeVg
Tony
Feb 10, 2013 | YouTube Videos
How to fix loose cross hair on david white transit
This is how I replaced the cross hairs on my David White 8080. Disassemble the tube piece nearest the eye. There is a small ring that holds the hairs, it has small marks on it to indicate where the hairs are to be attached. Use a large lighted magnifying glass. Remove the old hairs. Take some plastic model glue and using a toothpick, place a very small amount on the marks to anchor the new hairs. This type of glue will produce strings or "hairs" when beginning to dry if you use a toothpick to stretch them out. Place some drying glue (several seconds old out of the tube) on one of the marks, and pull the toothpick away (creating a hair) and pull it across the ring to the mark on the other side. Repeat for the second cross hair. With a little practice you can make some very nice cross hairs.
Dec 16, 2012 | David White 44 8834 1 22x Level Transit...
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Cross hairs wont move when trying to ajust
The cross hairs don't actually move when you adjust a scope, instead, they are contained within what is called the erector tube. When you adjust your scope you are actually moving this tube, thus the cross hairs do not move around in your field of view
Sep 19, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
No cross hair on the scope
hey there welcome to fixya
try going into your gaming options im sure you can set the crosshairs there
please remember to rate this solution
regards
magical ink
Jun 20, 2010 | Groove Games CTU: Marine Sharpshooter for...
At what power is the 6x24 banner set up for the mil-dot?
The cross hairs don't change with magnification. No matter what you set the power on, the mil dot doesn't change, until you move the cross hairs or dot. Unless they got something new out there I don't know about.
Feb 14, 2010 | Bushnell Optics
Not a problem but need operation instruction for my scope.Its a tasco pronghorn 3x9x40 with adjustable yardage and has two elavation cross hairs,I have had it for many years and it works perfect,but I have...
I believe the second cross hair in your scope relates to an 18 inch dimension, or that of a deer. When you adj the wire to the body of a deer, it will be the distance, I'm not sure if you have to do the math, or the scope does it for you. Some scopes, you had to figure the hold over by the distance in the scope. others would be set to shoot at that distance. I would ave to look that one for you to be sure, but that is the idea. Hope this helps.
Nov 11, 2009 | Tasco PH39X40D 3-9x40 Pronghorn Riflescope...
Convergence line will not move to match cross hairs
the green line will not move. it is stationery and red and blue have to adjusted to it
Jul 20, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Multi point convergence
In the multi-point adjustment grid use the exit/status button on the remote to lock onto the cross-hair that you want to adjust and again exit/status button to continue back to moving the cross-hair around to another location.
Bill
Dec 01, 2007 | Philips 43P8341 43" Rear Projection...
Winter Sports Logo
183 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
