Question about GE Kitchen Ranges
GE XL44 Oven and stovetop work - broiler does not work
We have a GE XL44 range. The surface burner and the oven work but the broiler does not work.
  • Anonymous Mar 24, 2014
    touchpad not working
  • 4,066 Answers
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Posted on Feb 04, 2010
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven won't light.
    Make sure your oven timer is not set for automatic cooking
    Dec 06, 2009 | GE Ovens
    Xl44 oven burner pulses, doesnt properly heat up.
    it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
    Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Lower oven burner will not light.
    Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
    May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven and Broiler not working
    The gas supply valve to the oven/broiler is the likely culprit. It is a separate valve from the stovetop. I've had the same problems and had to replace mine twice now. They are very expensive, (about 100 dollars) considering the cost of the whole stove. It is located
    inside the broiler drawer on the very back wall.
    Jan 01, 2009 | GE Spectra JGBP35 Gas Kitchen Range
    My Oven and broiler won't heat but stovetop burners work
    I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
    Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    XL44 Gas Range will not light
    Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
    To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
    Nov 27, 2008 | GE Ovens
    GE spectra xl44 - Oven not working, broiler & stove-top burners fine
    replace the ignitor for the oven. it's the lower one and not the one on top.
    Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE spectra xl44 not work
    I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
    Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kitchen Ranges Logo
    360 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
     Fix Your Board
    Fix Your Board
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
