Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Oven won't heat up
When set to bake or preheat, bottom burner does not lite, however, broiler does work
  • 221 Answers
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Posted on Feb 04, 2010
Turn my oven to preheat, broiler comes on and not the bottom element. Checked the ohms on element and it did move the meter.
Check the broiler element, and see if get the same reading.
Does the oven heat on normal "bake" settings? If so, the bottom element is fine, and it's the "brain" not telling the bake element to get hot.
Jun 08, 2015 | Ovens
Why will my broiler work but my bake will not?
Good Afternoon Friend,
I understand that the broil element is heating in your Frigidaire oven, but the bottom bake element will not heat. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When you restore power you will need to set the clock. Preheat your oven using the bake option. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Ovens
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Wont Preheat
does the bottom element get hot? could be a bad heating element.
Feb 01, 2009 | GE Kitchen Ranges
Oven Not Working
It could be the element, but if neither the top or bottom element are coming on, it could be an issue with the electronics... Have you tried any of the other oven functions? Is it a convection oven? Maybe try using the convection bake or roast/convection roast functions..(roast function doesn't go through a pre-heat cycle, I have the same stove). If it's still under warranty, I would be calling for service.
Jan 06, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
475 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
