Question about Music
Guitar pedal power problems
My guitar pedal will work when individually plugged into a power supply, but when its chained it kills the powers supply to all of the pedals. I dont want to buy an individual power supply for it... so what do I do?
  • Music Master
  • 5,603 Answers
Wow! All these are supposed to have a standard polarity connection.
Verify that this pedal has the opposite polarity of the power.
Frankly, having a second supply is expedient solution... The only other way is with blocking transformers or capacitive coupling...
I have never heard of a pedal having opposite polarity. PLEASE fill us in on this problem for future reference.
Posted on Feb 04, 2010
Testimonial: "Yeah, my power supply has a light on it, and when the defective pedal is plugged in the light flashes. So you think maybe the polarity is off??? "
Why are there only two dots when I power on?
1. Make sure that you have the correct power supply plugged in.
2. If you are using the BOSS power supply, it could be defective. Measure the voltage it is producing and make sure it is correct.
3. If the voltage is correct, then the problem is inside the unit, and it will need servicing.
Jan 07, 2016 | Roland Boss ME-70 Guitar Multiple Effects...
When I plug the damper pedal into my Roland ep 77 the damper comes on and stays on no matter if the pedal is pressed or not pressed.
Try plugging in the pedal with the Roland powered down or off. With the pedal plugged in, turn the Roland on again. The Roland should sense the polarity upon power up. If this doesn't work, I have had those pedals get defective right out of the box, so try this...Get a ¼ inch guitar or signal cable and plug that into the damper jack. The cable will represent an open circuit polarity since nothing is shorting out the leads. See if the EP77 is sustaining or if it is not. Alternately, try shorting the guitar cable by laying a piece of metal across the top and bottom of the jack. A pocket or kitchen knife or any bare wire will do. If this does not work, your assumption about the power supply may be correct.
Dec 26, 2014 | Roland Music
Must I remove battery when using auxiliary power supply?
I can't see any reason to do that unless the battery gets old. When you plug in the adapter, it automatically switches off the battery.
Mar 23, 2014 | MXR Carbon Copy Analog Delay Pedal Guitar
Input and/or Output for pedals not passing sound through
I will answer this assuming you have connected the inputs and outputs of both the pedals AND the amplifier/guitar properly. Double-check your connections! ;)
Otherwise...Have you checked all the patch cables to make sure they're ALL working properly? That's usually the culprit in a situation like this, all other things being equal. Cables take the majority of abuse in your signal chain and also happen to be the weak link in the signal chain as well. It only takes one bad patch cable in a series to interrupt the signal.
I would take a pedal with perfectly functioning inputs and outputs and use it to test each cable yer using. If you verify all the cables are in fact working properly (and you are 100% certain everything is connected correctly), that indicates there might be an issue with the pedalboard's onboard electronics. At the most simple, the "From Guitar" or the "To Pedal" or the "To Amplifier Input" jack might be bad. One or more them, in fact, but it only takes one to entirely interrupt that signal chain. The loop section is less straight-forward in that if one of the loops has a bad input or output jack, that shouldn't affect the overall signal chain, nor the inclusion of the other pedals in said signal chain.
So, I think it's one of three things:
1. The pedals, guitar, or amplifier are not properly connected;
2. You have a bad patch cable;
3. Something has gone wrong with the electronics onboard the pedalboard, and this will probably require service.
Hope that helps.
Johnny
Nov 30, 2017 | SKB Corporation Skb Ps-45 Professional...
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
This is for the takamine DI+. Is there a wiring diagram as to how to cable from my guitar to the amp? Basically how do you connect the DI+ using stomp boxes. Also, is their a special cable to use to...
Most of the pedals are daisy chained right from the guitar. The output of the daisy chain goes into the DI box set to ground lift. An XLR to XLR cable goes from the DI box to the amp or mixer. Do NOT try to loop the sends and receives of the amp through PEDALS! The sends and receives are LINE LEVEL which is too high for pedals. The sends and receives are for external effects MODULES and EQ's that take line level. Some of those effect units have a foot switch to turn them on and off.
May 05, 2011 | Takamine Acoustic DI+ Direct Box
There is a constant loud hum/buzz whenever I turn the pedal on. With my Boss Mt 2 Metal Zone effects pedal. It happens whether or not the power supply is plugged in. Ive tried switching cables and...
First and foremost , check your signal chain. By that, i mean put the pedal aside, ...just unhook it and take it out of your signal path. Using the same cables , guitar , amp, other pedals - borrow a friends MT-2 if you can get one , and try THAT to see if THAT works , OR any other kind of distortion pedal. If another one works ok , it's YOUR MT-2. Boss pedals are pretty rugged , but sometimes the little actuator (on/off switch) underneath the treadle (where you push your foot down) will become faulty. That's a high-gain pedal - are you using a basic Strat or other single-coil pickup guitar? If so , are you playing close to any flourescent lights? SIngle coils are noisy around those lights. Will cause a hum / buzz if using a heavy dist. pedal. You can check that by moving around as you play.
Nov 02, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Foot pedals no sound
1. No power to the pedals. Check battery or external power supply
2. Input device (guitar , etc.) is not working properly
3. Bad connector cables , or cables not plugged in all the way.
4. Individual levels on pedals turned down all the way.
5 Bad / non working pedals
Oct 09, 2009 | Music
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Digitech RP90 Expression Pedal
Same thing happened to me but i didn't drop the pedal.Try to recalibrate the pedal cause mine worked after that.Look in the Owner's Manual at the recalibration section.Hope this will work for you.Good luck with it!
Mar 29, 2009 | Music
Music Logo
179 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
