Question about Apple iMac G4 Desktop
When i turn my mac on a blinking folder with a question mark comes on
  • 863 Answers
Your Mac is saying it cannot find the operating system. Usually due to corrupt startup files or hard drive death.
Posted on Feb 04, 2010
Why does a question mark on a folder blink at startup and not turn on laptop?
Hi Joe. It means that the start-up drive has some corruption of some sort. I've posted previously what to do in such situations so just search for flashing question mark and there's a walkthrough of possible fixes.
Mar 27, 2012 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
My MacBook OSX will not open and I keep getting a file shaped folder with a question mark blinking?
Hello
That looks like your Mac does not see the System folder, for multiple reasons:
- Your hard drive needs repair / change- Your system files have bad permissions or are missing (to check this, disk utility in the Utilities folder cane good help)- Your hard drive has been erased or partitioned.
Hope that helps
Sep 22, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Won't turn on
The problem in blank white screen is the display (LCD). Send it to a technician for repair. The blinking folder with a question mark is conflict on drivers. Have you installed a software lately? If you do please uninstall it. Maybe that is the cause of having a blank white screen.
Jul 12, 2010 | Apple MacBook Pro PC Notebook
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
Feb 02, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My Power mac G4 Quicksilver has problems. When i boot it up the chime comes on, and i see the boot up screen. Although in the middle of the screen there is a folder that is blinking a ? mark sign. I tried...
The folder with the blinking question mark means that your Mac cannot find a bootable system on the internal drive. This usually means either that the drive has been corrupted or is not accessible. The proper repair procedure is to boot from the system installation CD and use the Utility menu to run Disk Utility / Repair Disk on the internal drive. But at this point, I'd have to ask you to elaborate on your claim that you "messed up your Super Drive" before I can figure out how to proceed from where you are.
Sep 26, 2009 | Apple Power Mac G5 Desktop
Blinking file folder with question mark and a DVD is stuck in it
Hello, The blinking file folder with the question mark can happen when the computer doesn't "see" your System. It can be caused by a faulty hard drive, or by a damaged operating system. You can try to reboot the mac, hold the mouse button during 20 seconds to eject the CD, then insert you installation DVD (leopard). Reboot the Mac again, and hold the "C" key. Select english, the go to the tools menu, and Disk Utility. Go to the SOS tab, select your drive and click "repair". If something red appears, it means that it has found something wrong on your hard drive. Best regards
Jun 10, 2009 | Apple MacBook Mac Notebook
Question Mark folder in my mac notebook
hey if you have the Utilities disk or any Mac OS install disk, place that in the computer, restart and hold down the c key.
That prompts the computer to boot from the cd.  If it gets past the question mark folder, then we are making progress.
At this point exit out of the installer, (unless you want to do a new install)  look through the top menus, to find the utilities options that will allow you to run a diagnostic and repair.  That should get you on the right path.
Let me know if this gets you back up again.
I do have some other steps that may also work if the problem persist.
Have a great one!
enov8  = )
Mar 05, 2009 | Apple MacBook Laptop Computer Mac...
My Mac wont work. blinking Folder with "?"
When the "?" mark comes up, it means it's looking for the operating system to boot to. It can be fixed by opening system preferences and in the startup settings, select your operating system as the tarted startup. It should speed up boot up time.
Apr 06, 2008 | Apple Power Mac G5 Desktop
Apple iMac G4 Desktop Logo
204 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
