Question about Refrigerators
Hi, where do I find the model number for my older refrigerator, please?
  • 52 Answers
Inside the side of the fridge itself, on the wall near the doors, or on the door panel itself.
Posted on Feb 04, 2010
Compresser doesnt come on
To direct you to the correct part I would need a model number. But you can look at the compressor relay and see if its burnt out. Unplug the unit, remove the back panel, some newer models are board controlled and older one are relay controlled. I would need more information to assist you properly.
Good Luck
Jul 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Tip
Finding Your Model number on Older GE Refrigerator (Frige)
Finding Your Model number on Older GE Refrigerator <br /> <br /> If it is a side by side look in the frige side on the side walls near the bottom. <br /> <br /> Also check the bottom right side of the frige between the door and the base.
on Mar 23, 2011 | Refrigerators
I have an older Jenn-Air fridge model # (P) JCB2280HES. We recently moved and now it is warm. not cool at all
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Jun 24, 2011 | Jenn-Air JCB2280HES Side by Side...
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
How do I tell the year an Admiral refrigerator was built?
Most older refrigerators will have the Date Of Manufacture stamped on the model number tag. Most newer models after 1990 will not have the DOM.
If no DOM is present, you can tell if your refrigerator or freezer is made before or after 1995, IF you still have the model number tag. This tag always has the model and serial number, as well as some technical information, including the refrigerant type used in the system. Models made before 1995 will use refrigerant 12, or R12, models 1995 and after will use refrigerant 134A or R134A.
Mar 28, 2010 | Refrigerators
We have an Amana side by side. The freezer door
hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Nov 17, 2009 | Refrigerators
    Hi,i would like to buy a used imperial ref. what
    Its really hard to say, if it is an older model from the mid to early 80's and older, it may last for quite a number of years but is not very energy efficient.
    On the other hand, if it is a newer , 1990 and newer, the life span is from 7 to 11 years.
    Hope this helps.
    Regards,
    Oct 02, 2009 | Imperial Refrigerators
    Mark I Series fridge not freezing
    Please list the complete model number found inside the refrigerator on on the door frame. With the model number I will be able to help you better. If your refrigerator is an older model then with what you described could possibly be a defrost timer gone bad. Let me know what you find, Thanks,Sea Breeze
    Mar 23, 2009 | Refrigerators
    CAN YOU TELL ME THE SIZE, CUBIC FT, BY THE MOEDL NUMBER?
    If you can provide it, then it can be determined and given to you.
    Jan 01, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
    CLOG DRAIN FOR REFRIGERATOR
    Hi, thanks for the question. these new ,or older fridges have the drain tube, between the walls of the fridge , and what happens is the water in that drain tube freezes. so the water in the defrost cycle ,cant go down to the drain pan. to repair fridge must be turned off. for at least 24 hrs. insert a small plastic tube, from the drain tray up to the freezer, an blow up the tube to clear. thanks the appliance doc. please rate my answer thanks..
    Oct 07, 2008 | Frigidaire GLRS264ZA Side by Side...
    Refrigerators Logo
    26 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
