Question about GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite Refrigerator water dispenser mechanism will not turn off. I turned off the water from the valve under my sink that is connected to the water line, however, I can hear the dispenser still running (buzz sound). Can I turn remove the panel that houses the dispenser on the front of the door without breaking it? How then do I turn off or fix the switch?
    President:
  • 1,891 Answers
Most panels have 2 screws under the edge . remoce them and the panel will come off . there must be a bad sw or something caught in sw .. sw do go bad .. mm hope this helped feed back pls .
Posted on Feb 04, 2010
I have a kenmore elite refrigerator 795.79783.901 if I turn on water to fridge the water will not stop coming out of dispenser till I shut off the appliance waterm valve
you have a faulty valve on the dispenser.. possibly just a faulty micro switch keeping the valve open.
Neither are expensive.. but getting into the part of the freezer to change them, might be a bit tricky, as manufacturers always have hidden screws, to deter the uninformed, or to cause them to break more, and then call in the professionals. (them)
Apr 22, 2017 | Kenmore Refrigerators
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Water dispenser is slow
3 possibilities.
1. Water pressure is low going into the fridge- the way to test this is turn the water off, remove the line from connection in the back of the fridge and put it in a bucket to see the flow. The water should be shooting out with good pressure. If it is not, then you have a plumbing issue, likely at the valve under your sink.
2. Water filter is clogged- If your model has a water filter, it should be changed every 6 months.
3. Bad water valve. The solenoid valve in the fridge, right at the back where the water connects could be going bad and not opening all the way.
May 11, 2012 | Kenmore Refrigerators
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser not working ...already tried changing filter.
HI, the water inlet valve should be inspected for damage, or clogs at this time . This will be the culprit.(check for frozen lines as well)
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Nov 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
After unplugging and moving how do u turn the water back on for the ice maker and dispenser
All you need to do is connect the water line to back of the unit and open the valve. Got any more info, make model?
Sep 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Nov 03, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
292 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
