Question about HP 510 Notebook
Printer spooler wont work
Printer spooler wont work.when i go into prog to try turning on still wont work
  • HP Master
  • 12,061 Answers
You need to go to "services" and enable and set to automatic Click "Start"
Step 2 Click "Run"
Step 3 Type in "services.msc"
Step 4 Click OK
Step 5 Find Print Spooler in the list of services
Step6 Click "Start"
Step 7 Check "Automatic Start"
Posted on Feb 04, 2010
Printing sitting in queue wont print
The print spooler may not be working.
Start and stop the print spooler Windows XP
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
Aug 28, 2012 | Brother MFC-290C Printer
I installed a new Ink Cartridges in My Canon Multipass MP390 color inkjet printer and now it won't print, Though the machine is on the compartment that carrys the ink cartridges wont even move as it its...
Hi Good day!! well i know that you can fix it. 1st off all is there any message error in your printer? if none then we will try to troubleshoot it in the printer spooler. Printer spooler is located in the services. please try the following.
1. turn off in a few seconds and then turn it on see if the ink cartridge is moving.
2. Click "Start
3. Click "Setting
4. Click "Control Panel"
5 Click "Administrative tools
6. Click "Services you should be on the services box now.
7. in the service box find "Printer Spooler
8. Click "Printer Spooler" all you need to do is to restart the printer spooler Stop and then START it again.
Try to print now hope your ink cartridge move..
ReGARDs
JR
Oct 07, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
Spooler turned off
The print spooler servie might be turned off.
Click on start go to run type services.msc
locate print spooler double click it and then select startup type automatic and then click on start. close all the windows, restart the computer and then try again it should work.
Jun 22, 2010 | HP Photosmart C5280 InkJet Printer
Print spooler is not working it is neither getting uninstalled I have genuine cd of d same bt d message shows of installation is intrupted by some reason. please help . its urgent THANKX
follow the steps:-
create a new account on the computer.
shut the comp off and then restart the computer.
login with the new account
disconnect the printer from the computer.
goto control pannel/add and remove prog/ click on the printer prog and click remove or uninstall when you right click on it..
restart the computer and reinstall from the new user account
May 13, 2010 | Canon LASER SHOT LBP-3000 Printer
Won't print Dell V305
It seems to be an issue with the Print Spooler Service. Either the service is stopped or not started correctly. Try stopping and restarting the printer spooler services on your computer. For tips on how to restart the Print Spooler service, use the link: http://www.ehow.com/how_2319117_restart-print-spooler-xp.html. Now Reboot your system and try deleting the print queue. It should work fine now.
Good Luck!
-Abhishek
Jan 31, 2010 | Dell V305w All-In-One R840635AU InkJet...
Lexmark x3480
Try restarting the printer spooler in the windows service management console.
Sep 20, 2008 | Lexmark X3480 All-In-One Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
ahah..first things first...what Windows Operating system do you have...??
Feb 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
Both power & feed lights flash
Information gathered: Basically the printer carrier has stalled.
Lexmark documentation states that you should turn off your printer and wait a few seconds and turn the printer back on.
Restarting the spooler will sometimes do the trick as well.
Go to start, run
type: <cmd> without <>
Command prompt will open up.
Type: net stop spooler
The spooler will say it stopped successfully.
Type net start spooler
The spooler will say it started successfully.
Hope this helps!
Jan 20, 2008 | Lexmark JetPrinter Z22 Color InkJet
Printer
Try this first:
CAUSE
This error occurs because the Spooler service has not been started or has stopped working. To start the Spooler service, follow these steps:
1.Click Start, and then click Control Panel.
2.Double-click Administrative Tools, and then click Services.
3.Double-click the Printer Spooler service, and then change the startup type to Automatic. This sets the Spooler service to start automatically when you restart the computer.
4.If you want to start the spooler service immediately, click the Start button under the Service Status field.
STATUS
Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article.
From: http://support.microsoft.com/default...;EN-US;Q314876
Jan 16, 2008 | Acer Aspire 5100 Notebook
Print Spooler Problem
Click on start
click on run
Type services.msc
A box will open up
Make sure all items below are set to automactic
To make the changes double click on each item
change to automatic if diabled. Then click apply when you are done.
Restart the computer and try testing your printer again.
Printer Spooler
LexBce Server
Remote Procedure CallRPC)
Hope this solves your problem
Oct 20, 2007 | HP DeskJet 670c InkJet Printer
HP 510 Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
