Question about Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent
Gradual decrease in water temperature
My aquastar is approx 6 years old. The water temperature has gradually decreased over time with the same inlet temperature. The unit lights correctly. It is a natural gas unit. I have never performed any maintenance. Any ideas?
  • Gary Davd
    Gary Davd May 11, 2010
    i suggest you clean and flush the unit and install a Sediminate filter on the feed side
  • 25 Answers
Rebuild the watervalve or replace it. 6 year old unit means its probably one of the 125 series. Probably a polymer gray water valve. Pay attention to the venturi, most likely its very dirty. You can get instructions off the www.boschhotwater.com websight to rebuild this.
Posted on Jan 19, 2009
2002 jetta 4 cyl runs very rough, and firing order seems to be misfiring? engine is not overheating, although once warmed up it lags while excellerating. Noticed that it appears that sparking or arking...
Check timing of the engine is right using an engine timing light. Make sure the timing belt or chain isn't worn or slack. The head gasket could also have gone and may need replacing.
Feb 15, 2014 | 2001 Volkswagen Jetta TDI
How do I adjust temperature?
look for dial or % of power and decrease setting. also look for time cycleing. decrease time
May 03, 2012 | Kitchen Appliances - Others
Water is way too hot. Five year old GWH2400E NG is giving error code EC: Ionization failure during operation. set point temperature = 106, inlet water temp = 88, outlet water temp = 171, water flow = 12,...
Before calling service technician who has service manual and can test which part has failed, open following links for troubleshooting resources including steps below and phone number for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ETechSupport/Troubleshooting/tabid/1131/Default.aspx
Clean inlet filter
Check all faucets for clear pathway
This unit does not work with preheated water (solar assisted)
Incoming water above 70 degrees, avoid restricted faucets
Check that both temperature sensors are making contact and firmly mounted on respective cold and hot pipes.
Descale heat exchanger
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G2-13_Descaling.pdf
Aug 16, 2011 | Bosch AquaStar 2400ES-NG
My dishwasher just quit. No gradual breakdown. I t washed a load completely, did a great job, and wneh the next load of dishes were ready to be washed nothing. . .no lights, sounds or anything. I have...
what is the model number.
most likely the thermal cutoff relay has tripped. is it likely you had inlet water temperature much higher than recommended. Normally dishwasher use cold water (depending on model) and use own internal heater. Others expect warm water at the inlet.
Aug 01, 2011 | Maytag Dishwasher
Need to locate the motor blower resistor for my 1999 mercury mountaineer, it has dual air, the resistor for the back is fine but the one in the front is bad and i cannot locate it. Please help.
If you have a manual system, you have a resistor. If electronic, you have a blower motor speed controller. Please rate if this helps.
here is info:
Control System Outputs-Manual A/C
Blower Motor Switch Resistor
The heater blower motor switch resistor has the following features:
  • The assembly is located on the evaporator housing in the engine compartment.
  • Three resistance elements are mounted on the resistor board to provide four blower motor speeds.
  • Depending on the heater blower motor switch position, series resistance is added or bypassed in the blower motor circuit to decrease or increase blower motor speed.
  • An overheating protective device (thermal limiter) will open the resistor coil circuit when the temperature reaches 121°C (250°F) interrupting the blower motor operation in all speeds except HI.
  • The thermal limiter cannot be reset and is not serviceable.
Control System Outputs-EATC
Blower Motor Speed Control
The blower speed control is located on the evaporator housing in the engine compartment.
  • The function of the blower motor speed control is to convert low power signals from the electronic automatic temperature control module to a high current, variable ground feed for the blower motor (18527).
  • The blower motor speed is infinitely variable and is controlled by the electronic automatic temperature control module software.
  • A delay function provides a gradual increase or decrease in blower motor speed under all conditions.
Jan 10, 2011 | 1999 Mercury Mountaineer
Which side ofintake manifold does temperature gauge sending unit go on
Water Temperature Indicator Sender Unit
The water temperature indicator sender unit is installed on the engine into an engine coolant passage. The water temperature indicator sender unit reacts to the engine coolant temperature. Its resistance decreases as the engine coolant temperature increases.
Water Temperature Indicator Sender Unit Removal
swb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
  1. Partially drain engine cooling system as described.
  1. Disconnect engine control sensor wiring (12A581) from water temperature indicator sender unit (10884) .
  1. Remove water temperature indicator sender unit.
Jul 30, 2010 | 1998 Ford Mustang
A/C GE AEW10AM decrease temperature but increase humidity (?!)
you have water standing in drain pan or your unit is oversized, 600 sq. feet per ton in southwest area is standard,.
Sep 29, 2009 | GE Heating & Cooling
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Kuppersbusch IGVS 659.2/IGV 659.2/IGVS 649.2
Hi mike_poulton,
I'm Harvey the master Plumber.
Your question is: You have one of the above models and it has been a fantastic dishwasher but now it seems not to take in water even on rinse and the timer does not decrease.
Any ideas please the model is 6 years old and if too expensive to repaire it will sadly have to go.
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Kuppersbusch Dishwashers
Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent Logo
184 people viewed this question
Top Terminator Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Terminator Kitchen Range Expert? Answer questions, earn points and help others
