When the projector is on and you try to press any buttons...there is an error message that appears saying...All buttons on Projector are locked. How can I unlock the buttons please? We can't even turn it off properly because even the power button is locked. Thank you and my email is ereupena@dhss.as or call me at (684) 733-5474.
    President:
  • 4,070 Answers
Good day. try to unplug the projector from the power source then press the power button for like 5seconds. after that try plugging the projector again and turn it on. see what happens. have a nice day
Posted on Feb 04, 2010
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    HOW TO RESET LAMP HOUR OF LG PROJECTOR MODEL BX-401C
    Try this, it works on older LG TV models:
    Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
    When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
    Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
    While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
    Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
    Press Exit on the remote to come out of the menus.
    Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
    Aug 31, 2014 | Office Equipment & Supplies
    How to find out lamphour in PLC-XT11
    hi
    do the follwing setting on your projector to reset the lamp hour
    1.Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button to move a red frame pointer to SETTING Menu icon
    2 Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move
    the pointer to [Yes] and then press SELECT button.
    3.Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
    ok
    Feb 02, 2011 | Sanyo PLC-XT11 Multimedia Projector
    How to reset lamp hrs.
    hi
    you can reset the lamp hour by the following settings
    1.Power on the projector
    2.Press the EXIT button on the projector for 3 second to display the total used lamp time
    3.Press the MENU button on the projector (adjustment message will appear
    4.Press the LEFT ARROW or RIGHT ARROW button to to reset the lamp hour
    5.Press the EXIT button
    ok
    Jan 18, 2011 | BenQ PB2220 Multimedia Projector
    Message
    Reduce the screen resolution to 600x480 for instance and see if the projector can handle the low res output OK. Then increase screen resolution on the PC unitl the error message appears. Try the video menu settings in the acer
    Jul 17, 2010 | Acer X1230 DLP Projector
    PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
    1.Press the MENU button to display the menu screen, and
    then press the F or G button to select the OPTION menu.
    2. Press the ENTER button, and then press the F or G button
    to select LAMP RUNTIME.
    3. Press and hold the ENTER button for approximately
    3 seconds. The confirmation screen, “LAMP RUNTIME
    RESET.
    ” is displayed and select OK.
    4. Turn off the power.
    �� This will reset the cumulative usage time for the lamp
    unit to zero.
    ***Here you go and best of luck!***
    May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
    Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
    If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
    hope this information was useful to you.
    Jan 21, 2010 | InFocus Office Equipment & Supplies
    Projector Problem- Screen appears Blue
    Hi there
    Press the source button on your Projector until it reads RGB.
    If this doesn't work , right click on your desktop and go to properties - check that your seconadry screen is attached in your advanced settings.
    Apr 26, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
    LCD projector no signal message
    Usually means that the computer is not sending a signal out the the projector via the monitor cable. Most Windows based laptop computers allow you to connect to a second monitor by pressing the Fn + F7 or F8 key, once to allow just the projector, twice to allow both the projector and laptop screen and three times back to only the laptop.
    Feb 18, 2008 | Office Equipment & Supplies
    Help me Please
    I have just reset my lamp! Disconnect all cables but the power, switch on it will search for a source, the lamp timer message will display press exit untill it will give you a message to press menu to reset the lamp timer, it will give you a option to press left or right to reset. I used the buttons on the projector not the remote.
    Jan 31, 2008 | LG RD-JT40 Multimedia Projector
    16 people viewed this question
    jasbo
    jasbo
