Question about Minolta PagePro 1250W Laser Printer
Minolta PagePro 1250w prints out pages with ink smudges. I have put in a new toner cartridge and still have the same problem. I tried to clean the areas in the printer with ink powder on them and removed a lot of it. But I still have large amounts of powder smudged on the printouts. How do I solve this?
  • cerney Feb 04, 2010
    The really bad smudging appeared recently and I have printed about 100 or so pages like that using both the old and a new toner cartridge. What do you mean by PM intervals? Do you suggest that I clean all those parts you mentioned or is it time for a new printer?
  • cerney Feb 05, 2010
    Your suggestions were helpful. I will look into what you said.
  • Minolta Master
  • 16,037 Answers
How many pages have you printed with it?
There are a lot of parts that have maintenance issues in laser printers.
THis could be the corona wire or the fuser or the drum. A dirty laser will also cause the images to smear and drop. They are a pain in the rear to clean and that is why there is PM intervals on them. Until you have eliminated all the loose toner, you will have to do that in order to track down what else it could be.
Posted on Feb 04, 2010
  • Brad Brown Feb 05, 2010
    I would recommend that you give it a fantastic cleaning. The Term PM means preventive maintenance. There are a lot of things that have to be cleaned on the printers. They also can be replaced. They include wipers, drums, fusers, chorona wires, laser diodes, toner trays and and rollers, A lot of those items are included in single units but you still can have issues. I would not go out and buy a new printer because of this. YOu can take it in and get it serviced and cleaned for less and save money in the long run. Just keep in mind that it is like your automobile, you have to change the oil and check the other things on it regularly or it will fail.
  • 1,110 Answers
Most likely cause is the drum unit. Drum unit is the unit that your toner cartridge attaches to. Remove this unit and slide open the cover on the bottom. You should see the green colored drum cylinder. It should be generally clean with no toner all over the surface. Also if you tap on the unit over a sheet of paper it should not be leaking or dropping any toner. If you have a new unit by all means try it but if you inspect this unit and see toner on the drum then that is your cause. You can find replacement drum units for around $75.00 so not too expensive.
Good Luck
  • Edwin Martens
    Edwin Martens Feb 05, 2010
    Great and Thank You. If my suggestion was helpful and it turns out to be the drum unit then please update my helpfulness rating.
    Thanks
  • Edwin Martens
    Edwin Martens Feb 11, 2010
    Any updates as to wether the drum unit was at fault? Fixya says that you rejected my help with this issue so I am wanting to see if I can assist you any further with this problem.
    Thanks
Printer driver pagepro 1250w won't install what to do
What os is being used the print drivers may be to old to use look up the spec on the printer I believe this printer is legacy Minolta/QMS windows95 or xp at best
Oct 28, 2011 | Minolta PagePro 1250W Laser Printer
I need afuser unit part number for a pagepro 1490 mf
This unit has a toner/fuser replacement part.
The part number is 9967000877 and should be replaced every 3,000 pages (avg).
I hope this helps.
If you like my answer please give me 4-thumbs up rating.
Thanks.
Aug 08, 2011 | Minolta PagePro 1250W Laser Printer
White streaks
its not the toner..there is something on the developer that blocks the ink in the same spot ...just open it ,,and clean it all..rollers developer..and all and it will be ok ...
Apr 28, 2010 | Minolta PagePro 1250W Laser Printer
I have a Konica Minolta pagepro 1350W printer. I
Please diregard. Since I was using an aftermarket toner cartridge, I took a chance and bought an OEM cartridge and... voila... it's working fine. Apparently, all I had was a bad cartridge.
Oct 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Minolta PagePro 1250 poor print quality
It is not cost effective to spend any money repairing an entry level laser printer. Replacing the toner cart or drum is insanity. New B&W lasers equivalent in performance to the 1250w are available on sale for ~ $50. You can get the Samsung ML 2010 for $59 every week on sale. Also the excellent Brother laser. For that matter you can get the a Samsung color laser (CLP-300) for $79 on sale with a $150 rebate.. . Due yourself a favor and get a new printer instead.
The Minolta is a great printer but I bought mine for $50 at Office Max, where they will gladly sell you the drum for $79! Huh?
Jun 26, 2008 | Minolta Color PagePro PS Plus Laser...
Konica minolta qms pagepro 1250w
Looks like your drum cartridge is dirty / busted. 1710400. e-bay has some new cheap drum replacements for about 40$
Feb 25, 2008 | Minolta PagePro 1250W Laser Printer
HELP WITH INK LINES DOWN THE SIDE OF PRINTOUTS
If the line is solid from top to bottom of the page, the problem can be in different parts of the printer. Try a different toner cartridge if you have an extra one.
Jul 25, 2007 | Konica Minolta PagePro 1350W Laser Printer
Minolta PagePro 1250W Laser Printer Logo
112 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
