Question about Sirius STILETTO 100 MP3 Player
Sirius Stilleto 100 skipping issue
Do you have a solution to this problem?
  • 1 more comment
  • Anonymous May 06, 2008
    i can't get my stiletto to go into device recovery mode
  • markp_370 Aug 20, 2008
    I have the same problem - the channel I am listening begins skipping and repeating the last half-second or so. I cannot turn off the radio, and must take off the battery for it to finally stop.
    I ran a system recovery last night, and it did the same thing today when I was listening to it.
    It happened a few months ago and came and went every so often. In the last 24 hours though, it has happened about 5 times, including when I recieved the "Error" message, which lead me to the system recovery program.
    Any ideas what this problem is?
  • Anonymous Apr 02, 2009
    I have experienced the same problem and have run the device recovery three times in the past week and a half. Device has become a major POS. Works for about a day or two, then starts its skipping problems before it displays the feared error message. Am seriously considering not renewing my subscription when it is expired, which is a shame.
Actually, it happens outside, and won't work again until I manually take off the battery, and then restart it.
Posted on Aug 26, 2008
  • 97 Answers
Usually this is a signal issue and it happens when recording indoors mostly, right? The signal dropps but only for a second or two so when you look at it its fine. you've probably notived it cutting in and out when "live" from time to time. Use your signal meter built in to the device and find the strongest signal location. If that doesnt work or its not the problem, update the software. If that doesnt work try running the recovery software but only as a last resort because you'll lose your recordings.
SIRIUS Device Recovery (SDR) is a software application that helps you recover your Stiletto (SL2, SL100 or SL10) in the event of a complete system failure.
The SIRIUS Device Recovery program retrieves the latest version of software for your Stiletto from the Sirius website. NOTE: Performing device recovery WILL ERASE the entire contents on your Stiletto: all music, Sirius recordings, channel presets and any user preferences. The Stiletto will be reset to its original factory state. You can perform the revovery from the Sirius Studio software that came with your device or http://www.sirius.com/mysiriusstudio
Posted on Mar 18, 2008
How long does the battery life last on a stiletto 10 SL10PK1 of how long i can use it before i have to charge it again
My stilleto lasts about 1 hour, but it's been used for a while now. I would reccomend buying a new Li-Ion batery if you absolutely need long battery life.
Dec 30, 2010 | Directed Electronics Stiletto 10 SL10PK1...
Stilleto 2 keeps shutting down
It may be a problem with the power switch, I too had this problem. It seems like the power switch is stuck in "down" position as if you were holding it. I remove my battery cover (along with the battery) and gently jiggle the switch up and down to "loosen" whatever may be sticking it in place and it seems to work. I have encountered this problem several times. I did not send it out for repair. It works fine for me (knock on wood).
May 13, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
When I plug the stilleto into my car adapter it shuts down. Then powers back on to a screen that simply reads "Sirius Connect"
I had the same problem with my home dock, it worked after unplugging the power to the dock for a few seconds
Dec 07, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
I accidentally washed my sirius stilleto 100. Is
If this is a recent (1 or 2 days ago), there is a possible solution that might work. This also works with many cellphones. As you should know, the Stiletto 100 has a removable battery. seperate the battery from the Sirius Player. Get a tupperware bowl and fill it about halfway or so with dry rice. Place Battery and player in the rice and completely cover with the rice. Leave Battery and player in rice for 24-48 hours. After this time period, replace battery and start it up. If not working, give it another 24 hours. If after the extra 24 hours it still doesn't work, you may have damaged it beyond repair and you may have to consider buying a new one. If this event happened more then a few days ago, there may be ongoing damage to circuit boards and such and this damage may be irreversible. You should consider either taking in for repair or replacement. This is a better option if you have a no-questions-asked replacement plan. Some electronics stores have a service plan in which they will completely replace a damaged device, even if the damage was your fault and/or completely intentional. These plans aren't cheap, ranging anywhere from 20 bucks for cheaper devices to $100+ for more expensive devices, but should you damage your device for whatever reason, including acts of god, they will completely replace with no questions asked. Some stores don't even require you to have all the parts available, although some do, so you have to ask if you aren't sure. If you have the money, I would also recommend getting the plan for the replacement as well.
Here is a link to a video about how to dry out cellphones. This is the method I am talking about and it explains the process a tiny bit better. Site: http://www.switched.com/2007/08/15/how-to-save-a-wet-cell-phone/
I hope this information helps.
Mar 30, 2009 | Sirius STILETTO 100 MP3 Player
Can i use existing satelite antena on my audi
The antenna should plug into the Stilleto car kit if your Audi is equipped with Sirius already. Otherwise you will have to use another Sirius antenna.
Mar 07, 2009 | Sirius Satellite Radio Receiver
Speakers on right side of car not working when satellite radio is
Try rewiring the system matey, you proberly need to daisy chain them together
Feb 16, 2009 | Sirius Satellite Radio Receiver
Stilleto 2 error message
Truthfully, you will be better off just sending it back for a new one.
Dec 09, 2008 | Sirius Stiletto 2 Portable Satellite Radio...
SL10 - lock up
I had the same problem...... SL10 is overheating the BGA chip there is 2 of them so you need to open your radio and install some heatsink tape but if you listening at home just put a fan on it so it wont overheat .......................
May 15, 2008 | Sirius Stiletto 2 Portable Satellite Radio...
Stiletto 100 recorded content skips
Double check your signal strength during the time of day your recording sounds like classic signal drop. Could also be software issue or memory issue. As a last resort; SIRIUS Device Recovery (SDR) is a software application that helps you recover your Stiletto (SL2, SL100 or SL10) in the event of a complete system failure.
Jan 19, 2008 | Sirius STILETTO 100 MP3 Player
Sirius STILETTO 100 MP3 Player Logo
487 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
