Need to configure for wirless setupnew dsl line from one isp to another need to set up router for wireless connection
  • 742 Answers
If you are setting up a new router for DSL connection, i presume that you already know the login credentials to access your router's admin interface. By default, depending on your router's model, you can access and configure it at http://192.168.1.1 or http://192.168.0.1 using a web browser and make sure that computer you are using is connected to the router through an ethernet cable.
Default login credentials:
user name: admin
password: admin (or try also leaving it blank)
When you are at the web interface, go to a link known as SETUP and there you can setup your connection. If your DSL provides you a user name and password, then you can also enter them there. Then save your settings.
To allow internet broadcasting using wifi, go to a link known as "WIRELESS" and setup encryption there using WAP, WPA2, or WEP or any other recommended encryption protocol. Through this, you can prevent other users near your place to use your internet connection without informing you.
Posted on Feb 04, 2010
Trying to hook-up a wirless router (Linksys WRT54G) to a SpeedStream 5100 for PS3 gaming on-line.
Before we configure router with PS3, we need first to make sure router is already configure to work with DSL modem. In Setting-Up a Linksys Router Using DSL Internet Service just click this link for reference.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=7a7ce39e35c34b5a9f641429eddc075f_4521.xml&pid=80&respid=0&snid=1&dispid=0&cpage=search
And for PS3 configuration to connect wirelessly to a wireless router, just access the link below
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=6dd5053ce9dd47ef9a78dd0623966bec_20556.xml&pid=80&respid=0&snid=3&dispid=0&cpage=search
Cheers,
Aimee
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
Cant setup or connect to internet through router
Different ISPs require different configurations. If you have a Linksys router, such as the WRT54G, there are 2 ways on how you can configure it, either by running the Setup CD or by doing manual configuration. This particular router has its own web utility and you can access it by typing its IP addres on your web browser, ex. http://192.168.1.1. By default, it doesn’t have any username and its password is admin.
Once you’re inside the setup page, you can configure now the router for DHCP, PPPoE or STATIC IP settings. For DSL customers using a PPPoE account, some modem needs to be configured into BRIDGE MODE first and then the router will be set to PPPoE with the correct username and password (given by ISP). If your a DHCP account, modem doesn’t require any configuration. It will work with its default setting and the router would be set to DHCP. Once done, powercycle your devices to establish internet connection.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
Search adress ip 191.168.... for my wirless router wrt54g to configuration
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Apr 06, 2010 | Linksys / WRT54G / 54Mbps / 802.11g /...
Im trying hook up a wireless router and it ask what kind of conection I have static ip ect... How do I know what I have? Im using DSL.
Most residential subscriber services use dynamic IP addressing. Dynamic IP addressing is automatic from your Internet Service Provider (ISP). Linksys home based products such as the one you have should be setup up for this configuration out of the box by default, and require no adjustments to the IP configuration of the wireless router.
You should power down the DSL modem and Linksys, then connect them, then reapply power. This will clear the DSL modem if it was connected to another device such as a PC. This is important as most cable and DSL modems use something called MAC address binding that will only allow one device to connect to it directly at a time.
Feb 06, 2010 | Linksys Wireless-N WRT150N Router
Router will not work wireless after switch from DSL to cable
You can go to 192.168.1.1
Enter the default username(leave it blank) and password(admin) and enter the router page
Under setup--> basic setup you can configure your ISP settings
Under wireless you can configure wireless username password etc
If still unable to connect wireless mention the operating system
Jan 29, 2010 | Linksys Wireless-G WRT54G Router
I HAVE A SHARP PC-GP10-CM MODEL THAT I WANT TO CONNET TO THE INTERNET WIRELESS, HOW DO I GO ABOUT IT PLEASE HELP.
First you need to sign up with an Internet Service Provider than can provide a broadband connection wirh DSL (ADSL in Australia) or a cable connection together with a wireless router with a built-in DSL or cable modem. Alternately a wireless router plus a separate DSL or cable modem.
The modem needs to be configured in accordance with the ISP's instructions.
Then the Wireless router and the wireless card in the computer needs to be configured. Follow these steps:-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
If you are not sure, then get a computer savy friend to help you.
Oct 21, 2009 | Sharp Computers & Internet
I dont know haow to connect Linksys Wireless-G Broadband Router with SpeedBooster WRT54GS - wireless router
  1. Connect your modem to the Internet port of the router. Your computer needs to be connected to one of the 4 Ethernet ports at the back of the router.
  2. Access the router's setup page by launching Internet explorer and typing 192.168.1.1.
  3. It will ask for a username and password. Leave the username blank and password is admin.
  4. Once your in the setup page, set "Internet connection type" with what your ISP requires you to have.
  5. If you have cable ISP, usually it is "Automatic Configuration-DHCP."
  6. But if you have DSL ISP, then it will be PPPoE. You need to know your username and password from your ISP.
  7. Better yet, verify your Internet connection type from your Internet service provider.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
Feb 03, 2008 | Belkin (F5D7230-4) Router (587009)
DI-524
make sure you have the wireless lan activated(software/hardware) and also configure your router's wireless setting(connecting thelaptop to the router by ethernet cable).write the wireless configuration down and configure your laptop with the same SSID and WEP key.it shud connect and you shud able to be good to goo..don'tforget to configure your DSL to therouter.post your router/modem/ISP details for further help
Feb 02, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
