Question about Watches
1987 ford pickup runs give it fuel dies out put new gas pump and filleder in dont know what too do
    Novelist:
  • 157 Answers
Need more info. a ford pickup in 87 may have had several different systems. there were recalls, tsb's etc. some had dual tanks. which tank are you switched to? then, what carb do you have, engine size?
or do you have fuel injection? it could also be a fuel tank selector valve problem. can you verify the new part is running in the tank after start-up? or they often had sticky fuel pump relays back then. so you see, this may even be a technicians nightmare. it will require a great deal of question and answer to get through this one vern
Posted on Apr 17, 2014
  • 27 Answers
Needs carberator kit to rebuild it.
Posted on Feb 04, 2010
My Hyundai accent will run for 3 miles and quit no fire to spark plugs in about 20 and will start and run
Tow to a shop of your choosing
You provided no year,engine or what was tested
& how,don't know if it's at a shop & fixed already
Timing belt break?
Fuel Pump may have worn out & just
turns on once in a while
Do some testing next time so we have something to go by
Jul 17, 2014 | Watches
How to change the battery in a CASIO CA53W-1 Watch with Calculator
open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
there is a spring inside that goes betweeen one of the contact holes. dont know which.
Jun 03, 2010 | Casio Watches
How to replace watch hands
first u have to get the right hands go to the web page of the make of watch or clock give them the serial no on back of watch thay will send the right ones. take the back of to remove stem there is a seting lever look on movement there should be a small arrow with a small hole at the end put a pin in softly and pull stem it will come out easy so dont force it once u done that take movement out still atatched to the face flip upwords so u can c the face put thin c through plastic over it so when u try to take hands of u dont damage the face use twesers and blue tac to put new hands on good luck
Jan 06, 2010 | Watches
Carbuetor promlems
Before removing carb a suggestion to check first,make sure distributor is supplying power to spark plugs and do inspect inside cap for moisture if there is no "fire"then that needs to be repared,"several things can cause this or if moisture is found clean distributor interior thouroghly and replace cap or it will happen again.if this is not answer try removing air filter for as long as possible along with plugs and let excess fuel evaporate before cranking anymore and add good fuel cleaner to fresh fuel and try again,old fuel can have condensation and not ignite.If you still find no change the problem may very well be carb and depending on how hard finding gaskets or replacement parts for it someone with experience may be needed for repair because carbs are difficult to do right without some knowledge.
Apr 20, 2009 | Watches
How to put back together a smith & wesson air soft rifle
ooof i know how to put i back together and can teach you but its a doozi over the net. hows your experiance with airsoft internals also wat type of gun is it (spring gas aeg etc shotgun assault rifle pistol etc. email me @ levis_lalancette@yahoo.ca i can help you further with that info
Mar 23, 2009 | Smith & Wesson SWW-357-R
Timex T5G341 sports universal
battery should always be original otherwise it will destroy your watch.dont try to put the battery yourself give it to an company autherised shop and allow them to put it
Aug 31, 2008 | Timex T5G341 Sports Radio Control Watch
Vauxhall corsa
u are the victim of counterfitting, your mainfold is not working at all. see aurthorized workshop. i dont know why people so stupid things, even they attempt to show their stupidity online
May 28, 2008 | Watches
Open a watch
Hi, this is easy to do what you need is a sharp knife then the back of the watch will have a case on it smaller than the watch you will see its raised and has an edge running all the way round. Sometimes their is a tiny recess running along the top or bottom of this cover this is to put knife into to pry the back off, not all watches have this. If yours dont then get sharp knife and pry the cover off from either the top or bottom it can be tight but get the knife so your putting pressure on to lift the cover up. The cover is only pushed in and it clips in so their is nothing holding it down.
Just keep prying it with a thin sharp knife untill the back lifts off it shouldnt be that difficult but just use thin knife and keep working it so as to lift the back cover off the watch.
This will give you access to the battery and once replaced the back just pushes on by hand push it on hard as this seals it from water and dust.
May 14, 2008 | Watches
Peugeot406hdi
It sounds like the pump may be faulty. These are not cheap ! Could be a faulty pressure sensor, loose pipe connection or blocked fuel filter. Check the fuel filter is clear of water and dirt. Check there are no visible leaks between the pump and the injectors.
Have you run it low on fuel ? It is possible to get air in the system, and as air is more compressible than diesel, the pump pressure sensor may be showing a low pressure.
Oct 28, 2007 | Watches
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
