My dayton heater will run for about 10 minutes and then shuts off with a small cloud of white smoke. I have to unplug the unit and hit the reset button to make it come back on for another 10 minutes. can you help?
  • 456 Answers
If it is keorsene Unit, it could be that the ignitor or
spark ignition either has a loose wire .
Posted on Feb 04, 2010
I have a 18hp kohler it starts and ruins for 5/ 10 seconds and them shuts down and there is a cloud of white smoke
Air cooled engine ok ,
When the engine shut off did it white smoke out the garden it could be the head gasket
Low compression and it won't start poor compression and it might start but run poorly stall easily and white smoke produce because of unburnt fuel escaping into hot exhausts and vaporizing
Jul 03, 2016 | Garden
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 30, 2009 | Reddy R60A Utility Heater
UNIT LITES THEN GOES OUT BLOWING SMOKE
needs a new nosel and tuneup kit you can get it at sears for about 12.00 dollars
Dec 23, 2008 | Dayton 511 Utility Heater
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
