Question about Virtual Reality Sound VR3 CD Player w/ USB and Scan Disk Inputs
Safty brake feature
What do I hook my brown wire (safty brake) up to? I have a 1996 Olds cut sup. Please help me Thanks!!! Amy
    Scholar:
  • 75 Answers
K here's the thing. The weird wires for your safety brake, headlights, etc.
If you want to be able to use your player while driving, aka leave a movie playing and have the screen still work then ground those wires. You could either splice them into your ground wire or you can take and use the sheetmetal surrounding the head unit to ground them.
Oh and as for the reverse light wire. That one you will need to wire in if you're going to use the optional reverse camera that they sell separately.
Hope this helps, don't forget to click fixya! :)
Posted on Feb 20, 2008
Had extra wires not hooked up on my mp5720 jensen pink and brown any ideaes
the Brown wire controls the mute function on the aftermarket hands-free kit, Pink Parking Brake wire coming off the back of the unit. This is a safety feature that only allows you to view video while the car is parked. If you wish to bypass this the wire, then it does not need to be connected.
can tape them off
can tape them off
can tape them off
Feb 03, 2015 | Jensen Car Audio & Video
Where does the pink wire on a vm9312 hook up to on a 2000 dodge durango
the pink wire is the parking brake wire... so should be hooked up to the paqrking brake...
OR , you can put a switch on it to bypass the safty feature.
Oct 07, 2011 | Jensen's VM9312 Car DVD Player
Well for the camper there are for wires for the lights i have green wire that is the right turn signal and hooked it up on the right side to the green wire which is the right turn signal in the car then...
well, the following is the generic (standard) wiring for trailer plugs......
tail (clearance) = brown
left hand turn = yellow
right hand turn = green
stop (brake) = red
electric brakes = blue
earth = white
now, you said that you had connected green, yellow and brown, and white. which is all well and good, but you did not mention a red wire which would be for the brake lights.
I hope this helps, get back to me with more info to assist you.
Please vote if you liked this response. !!!!!!!!!
Jun 27, 2010 | Chevrolet Cobalt Cars & Trucks
Can't hook up a stock radio on a 1996 Bonneville.
here are the wire colors for your radio harness, hope this helps figure your issue out.
1996 Pontiac Bonneville Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Aug 14, 2009 | 1996 Toyota Avalon
Brake and turn signal lights stopped working on my 1996 Ford E150
You might have cut a wire or it could have broken or disconnected. Try tracing the wiring where you hooked up the trailer you may find one broken or disconnected.
Mar 26, 2009 | 1996 Ford Econoline
36V Cordless Reciprocating Saw Kit Model 1651K
Sounds like it is a "safty hook" to use when saw is not in use ei... hang on work belt as you are between cuts.
Please rate.
Mar 18, 2009 | Bosch 1651K 36V Cordless Litheon...
No responce from accelartor after brake peddle is pressed
If check engine light is on get the codes pulled.
Jun 04, 2017 | 1996 Audi A4
96 GMC k2500 Suburban 4x4 upgraded front acuator
on the top side of the transfer case near the shift arm ....there is a transfer case indicator swtch.... connect into the only brown wire on the switch.........Be sure to solder the wires together, scotch locks are a no no ,, will corrode and cause intermittent connection, wich can result in other 4 wd component damage
Jan 25, 2009 | 1996 GMC Suburban
Bypass the brake or hook it up
To make the unit work in a display cabinet
Put one side of the switch down to earth & the other to the parking brake sensor wire from the unit.
it will then assume the handbrake is on when the button is switched.
I do not recommend you do this on a driveable car ;)
Dec 12, 2007 | Alpine IVA-D310 Car DVD Player
Car Audio & Video Logo
101 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
