Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I use the RCA model 425 modem through Media Com. My wiring for internet enters a bedroom. Now I also want to hook up a tv using this modem. A Media Com employee suggested using a splitter. Will this work to hook up the tv?
  • 229 Answers
Theoretically you can because the purpose your cable serves is a conduit for data transmissions. Just a few cautions here. Just as in any circuit, the more the wire is spliced,split, or anything that taps into it on its way . to the modem will add resistance to the line, thus it could degrade or "slow down" your signal. There is a splitter I know mediacom haves that will help with lessening this effect.
Posted on Feb 04, 2010
    Problem Solver:
  • 6 Answers
First you need to be more clear on what you are wanting to split, if you want to connect your tv to the Modem (for internet apps like netflix) or if you want to connect your tv to the coax cable line for basic cable tv channels. if it is for internet apps you need a router to "route" internet connections because your modem can only support 1 device at a time without a router. if you are you want to split the coax line you want to make sure you have enough signal to you modem. to check this 1. open you web browser 2. insert http://192.168.100.1/ into address bar and hit enter 3. click on "Diagnostic" if "Received Signal Strength:" is greater then -2 dBmV and your "Power Level:" is less than 50 dBmV you are safe to use a splitter and connect your tv. but please get a splitter and jumper from you local Mediacom office and don't buy them at radio shack or try to make them!
Posted on Oct 22, 2011
How do you connect a RCA router to a Sansung HD TV with Xfinity update
Mary, if you have internet, you will have a modem device. This device may be part of the router or it may be a separate unit. In any case, once this is determined and your internet is shared you will be able to connect your tv to your router. Your tv may be a wifi compatible set or not. Depending on which type of set you have, you will either connect a cable to the router or you will have to set up wireless. Wireless will be configured on your router. Once this is done, you can configure your tv to use the wireless connection. For more information, I will need exact make and models of your modem, router and tv. Also, google is a great source for documentation. If you decide to tackle this on your own, set up your modem, set up your router, then set up the tv. Hope this helps.
Oct 06, 2013 | RCA DSB778W Wi-Fi Streaming Media Player
I have the rca dcm425c modem wired to my mac in my office. I want to use google logitech tv in my other room with my big screen tv. I was told all I needed to add was a router that I would hook up to my...
USB is NOT RJ45 connectors. They are very differant as in water and bar of steel.
RCA DCM425 Digital Cable Modem eBay
Read backside cable connections. "ETHERNET" connect to router "Internet" connection. Plug ALL devices into "Ethernet" dump USB cable and store away. USB may shut down Ethernet connection while connected.
May 24, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I need a datasheet of TV RCA odel FXR, year 1988
Necesito un plano de TV RCA Modelo FXR 425-E, un amigo necesita conocer con que Voltaje trabaja el Fly Back
Jan 29, 2010 | RCA F32450 32" TV
Rca modem flapping
If you still have the modem, disconnect the coax-cable.
Connect the Ethernet cable.
Connect the AC power.
On your computer:
Click Start
Click Run
Type CMD and press ENTER
Enter IPCONFIG and press ENTER
Look for the "default gateway" IP-address, e.g., '192.168.2.1'
Start Internet Explorer.
Enter: http://192.168.2.1
to see if you can connect to the web-interface inside the router.
Good luck.
Nov 06, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can't get Linksys wireless router & RCA DCM 425 to work together
ok, ur old modem was configured for those two devices to work to gether
so u have to do the same here
*have ur modem connected directly to ur comptie
*go to ur command prompt if u have vista ( start * search * type cmd)
xp (run then type cmd)
the type in the screen that poped up ( ipconfig) enter
*look for default gateway type that in ur browser address
*should take u in ur modem interfase go to (advandced | PPPlocation | then set that modem on
BRIDGE MODEM and the modem should restart then connect router that should do it
GOOD LUCK
,July
rate my service please
Apr 11, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Will dcm425 work on playstation 3
Check this thread:
http://www.digitalspy.co.uk/forums/showthread.php?t=555166
Feb 16, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
No connectivity from 1 laptop but connectivity with another`
Try resetting the modem whenever you change between those PC's some NIC's will hang a cable modem stuck on an address.
May 02, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
1,627 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
