2000 audi a4 1.8t heating problems blower working well but only pushing cold air or not hot enough
Sounds like the same problem I had on my A4 1.8T, it was the thermostat on the engine that needed replacing, had that done now working fine
Posted on Feb 21, 2010
Heat blow cold air
probably heater door that allows heat into the interior not working or whatever controls you have that opens this door defective...1st make sure ur getting heat into your heater core by feeling both hoses which should both be hot, if one not hot then perhaps the valve that opens the water flow through the heater is not opening...sometimes u can see this visibly whereas you can then try to manually open it...
Dec 12, 2013 | 2000 Pontiac Grand Am GT
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
Heater does not come on, Radiator fluid full. Fluid heats, heater does not work blower works heater does not get hot or even warm.
Probably air locked. check to see if one of the hoses leading into heater is hot. Other cause could be heater solenoid control valve faulty. Very unlikely that the heater matrix is blocked. Easiest way to bleed heater is to remove hose's when car is cold and GENTLY flush through with garden hose and push hoses back on when full of water, so you know you have a heater full of fluid. Hope this helps
Jan 11, 2011 | 2000 Jaguar S-Type
Audi A4 1.9tdi Quattro 1997- Blower fan was only blowing cold air. Changed intercooler radiator as it was leaking, but fan still blowing cold air. engine temp went over half and then came back down. Only...
REPLACE THERMOSTAT.MAKE SURE COOLANT SUPPLY PIPE OR COOLANT RETURN PIPE NOT STOPPED UP AND YOU HAVE ENOUGH COOLANT IN THE SYSTEM.REPLACE THERMOSTAT.CRANK ENGINE UP AND LET IDLE UNTIL WARM UP KEEP EYES ON TEMPERATURE GAUGE. WHEN ENGINE THERMOSTAT OPEN COOLANT HOSE SHOULD BE HOT.IF NOT TURN OFF ENGINE.USE LARGE RAG WAIT A WHILE BEFORE REMOVING RADIATOR CAP CHECK TO SEE IF COOLANT LEVEL DROPPING IF SO ADD MORE COOLANT.CRANK ENGINE UP UNTIL THERMOSTAT OPENS UP.HOSE WILL GET HOT.IF STILL COLD CHECK COOLANT LEVEL.ONCE YOU AIR OUT COOLANT SYSTEM RADIATOR HOSES WILL GET HOT SO YOU WILL GET HEAT.IF COOLANT LOW YOU WONT GET NO HEAT.
Jan 09, 2011 | Audi A4 Cars & Trucks
My is heat is not work?My car is blowing cold air instead of hot air, I have a brand new heater core,the thermostat is not sticking,I got anti-freeze in it,It's getting cold in I need heat.Please help me
first feel the heater core hoses see if both are hot if so then your problem is in the blend air door must be stuck on cold. is your blower motor blowing cold air if not your blower motor might be the problem. the blend air door is down by the blower motor.
Nov 17, 2010 | 1995 Oldsmobile Cutlass Supreme
Audi a6 heaters not given out hot air
this is more than likely a problem with your thermostat in the cooling system .heres a few things to check to be sure make certain your blower fan is on high and temp setting is in the hottest setting check to see if   air is coming from your heater ducts  also be sure to thoroughly let the engine warm up 10 to 20 minutes  before checking. if the air is blowing but  luke warm still your thermostat is stuck in the open position  and will cause the engine to run to cold and performance will also suffer as will your heat will not be sufficient  to heat the passenger compartment  this repair should cost no more than $150 max to replace buy a repair shop    this is a  common problem in older cars and this is generally   a quick  repair to be made  for almost any repair facility  should take under 45 minutes to complete once repair is started
Feb 16, 2009 | 2001 Audi A6
2000 s type jaguar has no heat
It will probly be the heater tap that is down by the radiator. It has a 3 pin plug with 2 control solenoids on it. If you can connect scope and check is switching to earth set heat around 19 deg c. If that is fine the tap has swollen seals and the only way to fix is to replace.
Jan 04, 2009 | 2000 Jaguar S-Type
I have no heat in my 2000 expedition. Is it the heating coil? Or could there be another problem?
Is the blower fan for the heater going on, but only cold air? If the fan is working, but no hot air situation, 1st check the coolant level, if it's low, the coolant won't flow thru the heater core, so little or no heat. If level is ok, what does the engine temp gauge indicate? Is the engine running normal temp range, cold, hot? Let me know answers to these questions so I can help u.
Dec 08, 2008 | 2000 Ford Expedition
I have a 2000 dodge caravan, no heat
Sounds like the air "blend" door might be inoperable. This door opens and closes a specified amount to regulate the amount of either cooled or heated air, as requested by the climate control unit. If the door is continually in the position which is bypassing the heater core (cold setting), the air will not get warm regardless of the condition/operation of the heater core. I'd suggest having this component checked.
Nov 27, 2008 | 2000 Dodge Caravan
Heating & Cooling Logo
329 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
