Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Cold water valve
Has anyone had issues with cold water valve leaking?WHere is best place to buy replacement part?
  • 129 Answers
1-800-457-3104
Posted on Feb 04, 2010
Washer dripping water into tub
You have a bad water valve and that's why the water is still coming in after you turn the washer off. Replace the valve and you should be fine.REMEMBER to unplug the machine before doing anything.
Dec 08, 2015 | GE GTWN5050MWS 27" top-load washer with...
I have a 740003pc the cold tap wont stop running
If you mean the drain valve, the cheapest, easiest fix is to buy a hose cap at the hardware store and cap it off. If you mean the relief valve which is located on the top or upper half of the heater, you must replace the relief valve. Do Not cap the relief valve it is a safety feature. If it leaks again you may have further issues
Dec 30, 2013 | Rheem Water Heater Electric 20 Gal 120V
Fixed leaking faucet, now handles leak at the base & the water pressure is low
No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
Nov 23, 2011 | Plumbing
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
I only get hot water, no cold water
More than likely you have a failed cold water solenoid on the water inlet valve. The valve is simple to replace. The following link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Prices can vary between these sites, so shop around for the best deal. If you have any questions about this repair, or require additional assistance, please let me know.
Sep 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaking into tub of Maytag la9806
Check the solenoids at the valve. Use a multimeter or ohmmeter to check for continuity. A lack of continuity means a bad solenoid. I'll attach a photo for reference. Hope this helped and best wishes.
Sep 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
First cold water was leaking into the tub now it pours into it
no need to buy new washer, replace the inlet water valve instead,its the valve which oyour hoses screws into behind the machine, debris has damaged the coil preventing it from closing properly
Mar 25, 2009 | Whirlpool Washing Machines
Water flows in cold side of water valve and out hot side valve
It seems unlikely that something went wrong just from moving it unless it got banged up!
It sounds like you may have stripped the hot side.
I'm assuming the water is going in the cold side and out the hot side and out the back.
If this is so and you are happy with just cold water try this:
Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
I hope this was helpful.
Good Luck!
Jan 20, 2009 | Maytag PAV2300 Top Load Washer
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Oct 03, 2008 | Hotpoint Washing Machines
Kenmore 110.92274100 Rear Panel Access - Cold Water Problem
the top panel comes off via 2 screws that hold control panel on
once this done yuo can lift the whole hob and front and side panel to expose the workings
the cold water valve has a filter inside the water entry so to check this just take off the hose to the machine and look inside hole
if this is ok then you may need to replace water inlet valves
i presume you have high pressure water if not buy valve that is for low water pressure
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
135 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
