Question about Poulan Garden
What is the correct torque setting for a new clutch on a poulan 4018wt chainsaw?
  • Anonymous Mar 17, 2014
    spark plug for poulan 4018wt
    President:
  • 2,220 Answers
Finger tight. It will set itself with use. Besides you may need to remove it again some day. LOL. HTH
Lou
Posted on Feb 05, 2010
My poulan 4018wt has been a hard starter from new. It started to act up out of the blue and started shutting off halfway into the cut and didn't always want to idle right. So I changed the spark plug,
I'd say the most probable culprit is the fuel.... I'd first try dumping the tank out, mixing fresh gas with the addition of a fuel stabilizer and start the saw. It'll quickly vent any old gas in the line and should begin to run fine with the new mix. If not, consider returning it to the service center for adjustment.
Never use gas that has sit on a shelf for months at a time as it becomes 'stale' (for lack of a proper term). Todays 'formulated fuel' can be a cause a bit of a problem for some small engines. Anytime you refuel, shake the can to remix prior to filling.
The oxygenated nature of the blended gas sometimes causes the chain saws to run a little 'lean'...meaning too much air to fuel ratio which could be a portion of your problem. A lean running saw will run hot and scoring of the piston or cylinder wall is possible. Some finely tuned professional saws need carb adjustments between the summer blend and the winter blend gas.
Mar 24, 2015 | Poulan Garden
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
Show me how to change clutch on 3314 p
Use a Poulan clutch tool and look at the clutch for the direction to rotate the clutch. There will be an arrow and It should be CCW
Sep 14, 2014 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Clutch on poulan will not turn
Typically you need a special tool to remove it.. you can get this from a chainsaw supplier or poulan.Here is a how to video.
http://www.youtube.com/watch?v=zf28-ztoHfg
Nov 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan wild thing with an 18 inch bar, 42cc 2 cycle engine that i'm trying to get a recoil and cover for and i can't find the model number for it. i went on to ordertree.com and thought i found...
Go on ebay and type in poulan chainsaw parts.They have a lot on there with pics. You should be able to find the right one.There are only about 3 different kinds.They usually sell for 10 to 20 bucks.
Mar 13, 2011 | Poulan 18" Wild Thing Chainsaw
I bought a Poulan 42cc chain saw at a yard sale with the clutch taken apart. How do I fix it.
You do not provide a model number The following saw is most likely not yours but can be used as an example (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP4218AVHD-Gas-Saw-Type-2/75.PP4218AVHD-Gas-Saw-Type-2.1.59.1.html
For specific instruction I need a specific model. The example has an inboard clutch, I will assume your does as well and the entire clutch assembly was removed (did/does it have an oiler problem?). Use the IPL as a reassembly guide ("Handle, Chassis & Bar Assembly" print) and reinstall all pieces up to the clutch drum. Watch the film it will help, I do not think anything needs to be torqued (left handed thread on clutch, loosen it to tighten it):
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
Install the remaining pieces. Different video also helpful:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Install the clutch cover and chain:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
All poulan chainsaws can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If needed an OM can probably be found here:
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 11, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My Poulan Bar & Chain Oil gets used up very, very quickly???
Results for a Poulan 4018WT Type 2 (WildThing)
That is excessive, make them repair it. Your saw is warranted for 1 year.
The IPL lists no oiler adjustment and the Operator's Manual doesn't mention any oiler adjustment.
Manual
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006-P4018WT-952802029.pdf
IPL
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P4018-545103414-952802151.pdf
If you using any Bar Oil (30 weight with stuff added to make adhere to your bar and chain) and not a light weight motor oil I recommend you contact Poulan and make them repair it. Anything you attempt may void your warranty, do nothing without an official OkeyDokey. Get names, dates, and times in an e-mail for any official OkeyDokeys and save a copy them somewhere a computer crash won't wipe them out.
Contact Poulan here:
Poulan.com The dash number of your serial number is the type.
http://www.poulanpro.com/node4033.aspx
or telephone during normal business hours EST here:
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1.800.554.6723
Have your chainsaw within easy reach, they will want your serial number.
Nov 09, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poland wildthing chainsaw
Take the screws out of the cover to the recoil. After removing the bar and chain, take a racthet with the correct size socket which should be a half inch; put ratchet in tightening position. Attach a pair of vise grips to the inner piece of the clutch just outside of the threads that screw onto the engine shaft. You may need to grab the grab the vise grips with a crescent wrench as close to the clutch as possible. Grab the crescent wrench and the ratchet firmly and turn, that baby should come right off. I just took my clutch and sprocket off of a poulan model 2055 a week ago and I am getting a new assembly tomorrow from poulan.It's not really hard to do, you can do it. Hope I was helpful!
Apr 26, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
46 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
