My washing machine isn't draing properly can hear the machine working but won't drain what might be the proble? Send me a email to: stixx_78@hotmail.com if you could please.
  • 714 Answers
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Feb 04, 2010
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Washing machine will not drain water
Here are some basic troubleshooting steps you can follow to help you determine why your washing machine won't drain:
1. Check the drain hose in the back of the machine and make sure it isn't kinked or flattened.
2. If it spins but won't drain, there could be a piece of fabric stuck between the inner and outer tub, or even the drain hose or pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. It could also be a faulty timer.
3. Are clothes soaked at the end of the wash, even though it appears to go through the spin and drain cycles? Worn or loose belts could be the culprit.
4. When the spin cycle starts, do you hear a humming noise? It could be a faulty or jammed impeller pump.
For more suggestions on troubleshooting and fixing this issue, check out Washing machine not draining. I hope this helps!
Sep 11, 2012 | Whirlpool Washing Machines
Whirlpool Ultimate Care II is not draing properly and water is flooding out during spin cycle.
remove the hose up where it connects to the tub and see if there isn't anything stuck there,you could still have something stuck between the tubs and it usually will end up here or you could have a damaged pump from the piece of towel you pulled out of it or there's another piece still up in between the tubs and hopefully you'll find it at the hole where the drain hose is.
Jan 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The lid switch is replaced but it is still not working
when you put it in the spin cycle can you hear the motor running but the machine won't spin?if so another common problem is the motor coupling breaks and i will send a video for this,if this isn't the problem let me know and i'll try to help you out.
http://www.youtube.com/watch?v=9K1KHEogf3c
Jan 16, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
It won't drain, code nd. Hose isn't kinked.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
Spin wont work and machine wont spin cloths
The machine mite not be draing if so cheak the drain pipe to see if it is bloked or not installed properly. if the water drains out and you hear the moter running the belt might of gone. but if the machine if not making a nosie the moter might be gone and there is two things to cheak before getting a new moter 1 cheak the cables a blugged in sucurly 2 make sure the carbon brushes are ok if it seams all ok the moter might be broken or the control panel.hope this helps
Sep 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My washer won't stop draing as it fills
Does the washer makes a full cycle properly and only problem is water's constinously draining ? If this is the phenomena, verify that the pipe discharged to the drain hose (the pipe that water going out from the machine)is at washer height up to one foot higher. Goog luck !
May 25, 2006 | GE WBB4500EWW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
