Looking at the schematic for your unit it has two indicator lights one for the right side and one for the left. The indicator light gets its power directly from the infinite switches. So one of your switches have a shorted contact, or your wiring for you indicator light is somehow grounded. I would first check the wiring to make sure that there is no visible break anywhere or that mice didnt get in a chew up anything (now saying that you have mice but ive seen it before).
The way the switches are wired it would could be either switch on whichever side the light is staying on. As far as i can tell there is only a left and right indicator light. It would require individual component testing to find the shorted contact, or you could just purchase a single switch it looks like they should all be the same part number and will cost about $30. Replace one swapping directly wire for wire with your old switch. If that doesn't take care of your problem then swap it out for the other one. You will probably need the first two digits of your serial number for your look up this will indicate the series number.
Hope this helps _MJ_
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Here
is a tip that I wrote to give details about why your cooktop will not
spark to light the burners..
Cooktop
Range Stove spark ignition does not work
heatman101
Here
is a tip that I wrote about the problem of the cooktop light staying
on.
Oven
Hot Surface Indicator Light stays on
heatman101
I havent checked this out yet but it certainly sounds like a good solution. Based on the response, this person does know my unit. Thanks, I will respond again after I try the solutions.
