Question about Car Audio & Video
1993 dodge shadow radio wire diagram i have a problem with my instrument lights on the dash board speed,gas,temp,gages lights will not come on the radio light is on and it plays and works good but i have orange (dimmer wire) wire to the ground wire. that what the autozone man said to do. and the radio dont have a dimmer wire WERE DO I CONNECT THE ORANGE WIRE TO FIXS THIS PROBLEM???
  • 4 Answers
What he said!
Posted on Mar 09, 2010
  • 1,871 Answers
Hello! I will assume you are connecting a factory radio for your 1993 Shadow.
Remove the Orange wire from ground...Listed below is wiring from car to radio; You may need this one day...You are correct; There isn't a dimmer wire...The Orange wire, from the radio, connects to the Orange/White of the vehicle...Grounding the Orange wire is causing your problem...
1993 Shadow...Orange/ White=Illumination...Red=Hot at all times...Red/White=Switched 12volts...Black=Ground
Factory radio...Orange=Illumination...Pink=Hot at all times... Red/White=Switched 12volts...Black=Gnd.
Car; Orange/White to Orange of radio
Red To Pink
Red/White To Red/White
Black To Black
Let me know how you make out..
Guru...............saailer
Posted on Feb 04, 2010
While driving, speed od, gas gage and cold/hot gage and amp all go to zero.
Loose or cracked wire(s) feeding dash instruments, could be at the back side of fuse box.
May 01, 2014 | 2004 Nissan Frontier
Wiring diagram dash light
FIRST OF ALL WHAT TYPE OF VEHICLE DO YOU HAVE? IF ITS AN OLDER MODEL CHANCES ARE REMOVE SCREWS AROUND INSTRUMENT PANEL EASE OUT PANEL REPLACE THE BULBS THAT ARE DEFECTIVE. ON MOST LATE MODELS THE INSTRUMENT CLUSTER IS JUST THAT A CIRCUIT BOARD SYSTEM AND YOUR ONLY OPTION IS TO REPLACE INSTRUMENT CLUSTER. MAY BE ABLE TO GIVE YOU MORE INFO ONCE I KNOW WHAT EXACTLY YOU ARE WORKING ON YEAR, MAKE ,MODE,ANY EXTRAS
Sep 10, 2013 | Toyota 4Runner Cars & Trucks
Dash lights work but no gauges in my 1994 dodge intrepid!! i have checked every fuse i can find in the dash and under the hood but they still won't work, they don't even flicker when i turn my key....
If you have a 1993-1995 Intrepid and you have a check engine light, you can find out what the codes are by following this process:
To obtain fault codes using the MIL (Check Engine Light):
1. Cycle ignition key to ON, OFF, ON, OFF, ON within 5 second (do not actually crank engine!!)
2. Count the number of times the MIL on the instrument panel flashes on and off. The number of flashes represents the trouble code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses seperate the individual two digit trouble code.
Example:
Lamp flashes 4 times, pauses, then flashes 6 more times. This is an indicates a DTC of 46.
3. Lamp will always flash 55 at the end of the test. This signals the end of the test.
You have put the computer in diagnostic mode and it will now display any codes that have been stored in memory. Each code will refer to a symptom your car is feeling.
Here is a list of all codes that can be displayed and what they mean:
http://www.automotiveforums.com/t355082-trouble_codes_for_all_intrepids_1993_2004.html
Post Back With A Code, If you get one.
I Hope this Helps,
Jos
jtobias1020@gmail.com
CHECK OUT THIS ARTICLE! CLICK ON THE LINK AT THE BOTTOM
I Know Yours is A 94' , They didnt change to much in two years. 1993 Dodge Intrepid instrument panel
JB DRUMLIN
  • 1993 DODGE INTREPID
Electrical problem
1993 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
All five guages of the instrument panel do not work.
ie: speedometer
gas guage
temperature guage
automatic quadrant selector
rpm guage
After reading through the Article, Pop the Hood and Check out the Grounding Locations. Look for any wire that looks like it should go somewhere. Screw it down (Ground) to the Frame Rail.
First Disconnect the Negative from Battery For a couple Minutes,
If the Engine was replaced they mighta missed a couple Grounds.
One is front Driver corner by the Battery
Two is on Passenger Corner.
1993 Dodge Intrepid Instrument Panel Electrical Problem 1993
I have a feeling there is a Loose Ground or an open, There should be 5-6 Volt Reading coming out of the Cluster,
Let me know how All this goes.
Jos
Feb 28, 2017 | 1994 Dodge Intrepid
2007 shadow sabre 1100 C2- temp light flickers when picking up speed then goes out at normal driving speed.
Hi, Johnburdine if your water temperature light comes on or flickers and the engine does not seem to be overheating the usual suspects are:
1. Faulty temperature sensor.
2. Loose light bulb wire in the instrument harness.
3. Chaffed or pinched wire in the bulb circuit making contact with a power wire.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Overheating Temp light issue
Honda shadow temp warning light Austinmotorcycles
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Aug 07, 2011 | 2005 Honda VT 1100 C2 Shadow Sabre
I have a 1996 Dodge Neon. My instrument gages work sometimes and then they dont. I get no readings (gas gage, temp gage and speedometer). Is this something that is easy to fix?
instrument cluster. either you can pull yourself @ clean w/electrical cirercuit cleaner but also suggest check fuses for a loose fuse
Aug 13, 2010 | 1996 Dodge Neon
My gauges (temperature, gas, speed, rpm) stopped working at the same time the turn signals and brake lights stopped working. I am assuming I blew something as it happened when I hooked my trailer up....
have a caravan ´93 3.0 motor mi problem is a temperature, gas,speed and tableboard light don´t work and the table indicates check gages
sorry i speak litle english
sincerity
a mexican friend
thak you..
jaibita2000@hotmail.com
Jul 09, 2009 | 1993 Dodge Caravan
Need dash wiring diagram for a 1993 Dodge Colt
i had this problem , all you need to do is hook the ground wire from your new radio to the braided wire that hooked on your old radio and insert a bolt in the hole and tightin ,then check fuses and your dash lights will work and dome light.
Oct 05, 2008 | 1993 Dodge Colt
Car Audio & Video Logo
258 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
