Question about Coffee Makers & Espresso Machines
Pasquini turns on (while cold) as normal. Operation is as normal for about 10 minutes. Then the heating indicator goes off and no longer goes on - even once the machine is relatively cold and pressure goes to zero. Its as if there was no water (although there is water) or as if it went into some "do not heat" mode.
  • 3 more comments
  • kk97 Feb 04, 2010
    Pasquini Livia 26384
  • kk97 Feb 04, 2010
  • kk97 Feb 04, 2010
    It does not seem to be the typical sticky pstat issue - as the pressure is well regulated during the first 10 minutes. It also does not seem to be related to an empty water tank - its full. An interupted wire doesnt seem likely given that it works initially.
  • kk97 Feb 04, 2010
    I agree that what I heard is a partial solution but I do not yet know what I should do.
    So it looks a little bit that something in the inside of the machine tells it to go into "Panic" mode. It then acts as if there was no water. Now. This sounds a little bit like the control unit has a problem. But replacing it based on that hunch is a bit hard - that unit runs 300 dollars.
    Anyone with real knowledge of the Pasquini Livia having any suggestions?
    Konrad
  • kk97 Feb 04, 2010
    It is good advice. Thanks
  • 506 Answers
I am not familiar with this machine however generally equipment that has a heating element or elements will have a thermostat. Not the kind of thermostat for your house heat, it is basically a thermal breaker. Bi-Metal thermostats can be normally open or normally closed. When the thermal limit has been reached they activate. In your case it sounds like you have a normally closed thermostat that is opening up. Again this is all speculation but as a rule of thumb this is for safety purposes IE so it won't catch on fire.
PS one way to tell if this is the problem is if their is a latent time period that you cannot turn the unit back on. The thermostats have to reset themselves by returning below the switching temperature.
http://www.skhitec.com/images/ElectronicsParts/bimetal.jpg
that link is an example of what bi-metal thermostats look like.
Posted on Feb 04, 2010
  • David S. Feb 04, 2010
    If you are looking for someone with first hand experience with this model may I suggest you contact the company directly. It isn't worth your time or wallet for people on here to hypothesize about what could be wrong with this very expensive coffee machine. Good luck with whatever you decide.
  • 15,935 Answers
What is the model # please?
Thanks
Trying to find which fuse is for the heated seats on a 2004 ford explorer sports trak
Heated Seats
This system allows the electrical heating of the front seats on passenger demand.
The components of the system are:
  • the seat heating elements located in the seat cushion and backrest.
  • the heated seat control switch, located on the seat side trim panel.
  • temperature sensors located in the seat cushion heating elements.
  • heated seat relay.
Do both front seat heaters not work ? Do you know how to test electrical circuits with voltmeter ?
PINPOINT TEST J: THE HEATED SEAT IS INOPERATIVE Test Step Result / Action to Take J1 CHECK HEATED SEAT SWITCH OPERATION
  • Key in ON position.
  • Press the heated seat switch on the driver and passenger seats.
  • Are both heated seat switch indicators illuminated?
Yes
If both indicators illuminate, Go To Pinpoint Test K . If only one indicator illuminates, GO to J5 .
No
GO to J2 . J2 CHECK THE HEATED SEAT RELAY CIRCUITS
  • Key in OFF position.
  • Disconnect: Heated Seat Relay C3250 (located under the driver seat).
  • Measure the voltage at heated seat relay C3250-86, circuit 1003 (GY/YE), harness side and ground; and between C3250-30, circuit 566 (DG), harness and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to J3 .
No
REPAIR inoperative 1003 (GY/YE) or 566 (DG) circuit. TEST the system for normal operation. J3 CHECK HEATED SEAT RELAY GROUND CIRCUIT
  • Measure the resistance between heated seat relay C3250-85, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to J4 .
No
REPAIR circuit 57 (BK). TEST the system for normal operation. J4 CHECK THE HEATED SEAT RELAY
  • Install a fused jumper lead between heated seat relay 3250-30, circuit 566 (DG), harness side and heated seat relay C3250-87, circuit 1064 (YE/LB), harness side.
  • Do both heated seat indicators illuminate when pressed?
Yes
INSTALL a new heated seat relay. TEST the system for normal operation.
No
REPAIR circuit 1064 (YE/LB) to switches. TEST the system for normal operation. J5 CHECK INOPERATIVE HEATED SEAT SWITCH INPUT
  • Disconnect: Heated Seat Switch C320 (Driver) or C321 (Passenger) for the inoperative heated seat.
  • Measure the voltage between heated seat switch C320-2 (driver) or C321-2 (passenger), circuit 1064 (YE/LB), harness side and ground .
  • Is the voltage greater than 10 volts?
Yes
GO to J6 .
No
REPAIR circuit 1064 (YE/LB). TEST system for normal operation. J6 CHECK CIRCUIT 57 (BK) FOR AN OPEN
  • Measure the resistance between heated seat switch C320-4 (driver) or C321-4 (passenger), circuit 57 (BK), harness side and ground.
Yes
INSTALL a new heated seat switch. TEST the system for normal operation.
No
REPAIR circuit 57 (BK). TEST the system for normal operation It's not that simple , being a fuse . It's probably the relay or the heating element .
PINPOINT TEST K: SEAT DOES NOT HEAT BUT THE HEATED SEAT INDICATOR ILLUMINATES WHEN PRESSED ? Does it ?
Your best bet would be to take to a qualified repair shop .
Do
Jun 29, 2016 | 2004 Ford Explorer Sport Trac
Recently had radiator, hoses, heater core changed. After 5 to 10 minutes of driving gauge goes up to just about red lines
make sure that there is no air in the system. Most vehicles have a reservoir and a fill location because the reservoir is below the top of the engine. take the cap off the highest point and then run the engine from cold. the air should work its way out. keep an eye on the antifreeze reservoir level top up as needed. once the bubbling has stopped replace the cap, and see how it goes.
Dec 05, 2015 | Cars & Trucks
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
The microwave looks like it is working but no matter what I do there is no heat. I put in a cup of coffee and hit the minute button. It turned on and goes around but the coffee is cold. So I tried...
HELLO.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    Pasquini Livia 90: heats up for about 5 minutes, then shuts off
    Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
    Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
    I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
    This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
    You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
    My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
    I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
    Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
    Our Livia 90 would need a service + the pressure steam valve is leaking. Thanks in advance ! Thilo
    If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
    As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
    Oct 03, 2009 | Pasquini Livia 90 Espresso Machine
    Pasquini. Livia 90 intermittently building up too much pressure
    The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
    You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
    These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
    May 21, 2009 | Pasquini Livia 90 Espresso Machine
    Electric furnace blows cold air before and after warm air.
    It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
    Nov 29, 2008 | Heating & Cooling
    Picture problem
    If the set is no longer under warranty, open up the back and reseat all of the connectors and cables. You are seeing a heat related connection problem. If it is still in warranty, bring it in for warranty repair. The other possibility is a heat related connection at the processing chip(s). This is a more complicated repair that should only be done by an experienced tech that works with surface mounted components.
    Keep us posted.
    Dan
    Apr 23, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
    Coffee Makers & Espresso Machines Logo
    27 people viewed this question
    Top Coffee Makers & Espresso Machines Experts
    Colin Stickland
    Colin Stickland
    Kolbrun...
    Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
