Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Side USB ports
How do I get the USB ports on the side of my Dell 24 Ultrasharp to work?
  • 472 Answers
You need to connect a USB cable from your PC to the USB port under the monitor.
It is a standard usb cable used by printers with a flat plug on one end and a squareish plug on the other.
You should also have 2 more usb ports under the screen as well. There are normally 4 on Dell screens. 2 side, 2 under, and the one square plug to connect to the PC.
Posted on Apr 08, 2008
Usb ports do not work
I have a 24" Dell monitor with built-in USB and SD sockets. Sometimes I have had problems with these not being responsive. This usually comes down to electrical connection.
You should do these in order, also testing for USB port availability at each step .
#1 is the monitor powered up? (USB is active only when monitor is switched on with power button on front of bezel)
#2 check that the USB cable at both ends is plugged in! (you need electrical connectivity)
#3 check that the USB port on the PC can see another device like a memory stick
#4 check your PC's software (drivers must be loaded and the USB port recognized)
Sep 25, 2012 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Can I use the USB ports on the left side of my Dell 1704FPT monitor to connect devices? (e.g., Logitech webcam)
yes you can use the usb port but let me tell you one thing very clearly there is problem with these ports either they dont recognize your usb or maybe your monitor screen flickers... so use monitor port with a lot of care and i advised you to atlest read the manual before you do anything.
Jan 08, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My usb ports on the side of my Dell LCD monitor do not work
Did it work before? It may have lost 5vdc feeding the USB interface board or the USB IC may have gone out, Check to see if pin 1 of the USB has 5vdc on it.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monintor does not read sd card or usb with inserted on monitor.
you need to connect a usb cable on it and attache the otehr end on the usb port of the comp
Mar 03, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Enabling USB ports on Dell monitor
On the back side of the monitor, next to the power connector, you'll find a USB "B" connector (the boxy, square one) You need a USB A-to-B cable to connect your PC to the monitor, not a male-to-male (A-to-A) cable.
Hook that up, and you should get the boo-deep sound from your PC as it adds the new USB hub that's inside the monitor.
If this helps, please be sure to hit the "thumbs-up" button for me!
Dec 14, 2009 | Dell UltraSharp 1909W Monitor
Dell monitor setup
There is a USB cable that goes from the monitor to your computer. It's the same kind of USB cable that is used to connect to printers.
Nov 21, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Usb ports on the side of the monitor are not live... how do I make them usable?
Run an A to A USB cable from the monitor rear to a Computer USB port.
Mar 06, 2009 | Dell UltraSharp 1905FP LCD Monitor
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
297 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
