Question about Maytag Washing Machines
Will not aggitate or spin,
Maytag washer, fills with water, but it refuses to aggitate spin or drain water out. replaced both belts. Can spin the drum and agg. by hand not frozen up. Could this be a switch problem?
  • ginsense Feb 04, 2010
    No.Not a lid switch.That seems to be operating properly.Lift the lid the dial stops, close the lid the dial starts.Could it be the dial switch causing it not to start agitate? Model # LA108
  • 129 Answers
Lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Posted on Feb 04, 2010
  • ARNETTSREPAI Feb 05, 2010
    this is an older model maytag good strong washer . if the motor makes a noise like trying to run it could be the shaft has slipped down on the motor locking the armster underneath try to move motor shaft up and down. if timer makes noise possibly ok. if no leaks under seals and transmission it could be worth the cost of a motor. if water or grease appear inside cabinet or on floor under unit purchase new washer. thanks terry
My washer is 7-8yrs old it will fill with water but then will not aggitate,spin or drain
the lid switch is defective underneath the lid,disassemble the unit and replace this switch under the top and reassemble the unit
Sep 11, 2011 | Maytag Atlantis MAV6000 Top Load Washer
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
You start the washer and the water will fill up to where it is suppose to but will not start to aggitate.The water will drain but the drum won't spin,than it will fill up again and it won't agitate...
Your drain hose is maybe too low and therefore gravity is draining out the washer OR the drain hose is too tight in the drain and a siphoning effect is happening.
Sep 22, 2010 | Hotpoint Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Washer will not aggitate
LOOK AT THE LIDE SWITCH FIRST WILL IT FILL WITH WATER WILL IT DRAIN WILL IT SPIN IF THE ANSER IS NO TO ALL LID SWITCH IF ONLEY TO AGGITATE MAY BE A TIMER OR AGITATOR IT SELF
Apr 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag mavz757aww will fill but not spin
take a wet dry shop vac and attach it tothe end off the drain hose and remove all the water.once the water is removed move the washer away from the wall. tilt it back and look under the front you should see the drain pump and motor remove the two black hoses and look for anything stuck in the drain pump.
then look for a black rubber piece with two white plastic pieces on both side if this is broken then replace it this is your transmsiion coupler.
if there is nothing wrong with either one of these items then you may need to rpelace the lid switch.
Mar 14, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
Drum doesn't pin Model LAT8234AAE
It possibly the switch timer is defective.
Feb 24, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
165 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
