Question about Bowflex Treadclimber
Can't get Bowflex TreadClimber TC5000 to pass calibration.
I have a new Bowflex TreadClimber TC5000 that I cannot use, because I cannot get it calibrated. I have tried many times and I've followed the instructions carefully. I have also shut off the power, unplugged it and started over again.
The same thing always happens. I follow the instructions and it goes through the calibration process. However, after completion, instead of the display showing ''CAL'' ''PASS'', it shows ''CAL'' ''FAILED'' ! There is no information in the owner's manual on what to do if this happens.
I'm not mechanically inclined and had someone else assemble it for me. Could someone please explain (in simple language)how to remedy this problem. Thank you.
    Novelist:
  • 145 Answers
Hi There,
You said this is a new machine? Or just new to you? If it's new simply call the seller for warranty service. If it's not new, there could be an issue with the control board. If you were to just press Start and try to walk at 1mph, does the treadmill work? Does the treadmill not seem to be the correct speed being the reason to do a calibration? Lets also be sure to check the speed sensor at the front roller maybe, which should be close to a rotating magnet, which in turn, counts rotations or this roller and mathematically figures out the speed in which it is turning, then compares this to a table in the upper board to verify the set speed matches the rotating pulses of the front roller. You can contact jatinah@rocketmail.com for more help. Good Luck.
Posted on Apr 18, 2017
    Habit-Forming:
    New Friend:
  • 25 Answers
DEAR
AT FIRST YOU MUST REMOVE COVER AND SEE CAREFULLY TO FIND SENSORS SOME SENSORS ARE PHOTO SENSOR AND GET ON DUST AND CAN NOT GOOD WORK THEN BETTER THIS IS YOU CLEAN DUST VERY VERY GOOD PERHAPS SOLVE YOUR PROBLEM.
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Posted on Apr 10, 2017
2 Suggested Answers
  • 6 Answers
SOURCE: calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
Feb 02, 2016 | Bowflex TreadClimber TC5000
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
My tc5000 keeps failing the cal can you help
Try again RUN the software calibration. and adjust the REED SWITCH, and Speed Sensor, test it, clean it, and tight the plug or connector from UPPER board vs lower board.
God bless you
Nov 16, 2012 | Bowflex Treadclimber Tc5000 Tc 5000 W In...
After trying to cal my tc5000, I got a cal fail. I then pulled the saftey key and re-inserted it and it displayed boot clr
adjust the REED swtch, and speed sensor, test it, clean it, and tight the plug or connector.
2) Tight the upper cable vs lower cable
3) Tight the ribbon cable for keypads
4) Run again the s. calibration.
God bless you
Bowflex wont calibration or pass calabration
1= do not panic
2= Lube the deck belt
3= lube the roller bearing
4= adjust the REED switch see the diagram attached, clean and tigh the wires connector very well
5= lube the motor elevation very well gear and shaft.
6= adjust the potentiometer of elevation motor,
7a readjust again the speed sensor, see the diagram attached,clean it and tight wires connector very well.
7= Run again the software calibration for diagnose and troubleshooting
see the block diagram and fix it , maybe the main motor board is faulty, test it with the RUN s.calibration. God bless you
7_8_2012_2_00_09_pm.gif7_8_2012_2_01_02_pm.jpg7_8_2012_2_01_21_pm.gif7_8_2012_2_01_41_pm.gif
Jul 08, 2012 | Bowflex Tc5000 Climber Treadclimber...
I am having trouble with my Bowflex TC5000. The calibrations is failing. The treads aren't moving but the monitor is trying to calibrate.
The motor must move the drive pulley for calibration to pass. remove rear covers and check drive belt. you should hear the lwr board relay click to engage the motor. if you hear it and the motor does not move and you have checked the belt then you need to test the motor. Typically remove the belt and turn by hand...it should be very smooth and spin freely. If not replace the motor. Direct 9 volts to the motor leads unplugged from the board will tell you if the motor is good. be careful as capacitors are present and risk of shock is always possible. capacitors stay charged for about 10 mins after unit is unplugged
Jul 30, 2009 | Bowflex Treadclimber
The machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Mar 18, 2009 | Bowflex Treadclimber
My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Dec 07, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber Logo
881 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
