Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
My samsung frig suddenly started clicking (the bell that lets you know the frig door is opened.) checked to make sure all doors were closed but bell keeps ringing and now the temp. is rising inside. what's going on? we called service and they told us someone would call us back in two or three days to set up appt. i can't take two or three more days or the bell clicking.
  • jillbush1 Feb 04, 2010
    hi macmarkus:)
    i jiggled a wire on the back of the fridge and it stopped chirping and started to work again. so far, so good.
    thank you for replying and give me a suggestion.
    -- jillbush1
  • Samsung Master
  • 2,605 Answers
Can you pull the gasket back slightly (flat screwdriver or dull knife, don`t cut/rip the gasket) from the side of either fridge door and tell me if the cabinet light is on inside ? I need to know if the light is on without opening either door.
I`ll watch for your reply.
macmarkus :)
Posted on Feb 04, 2010
  • Mark MacDonald
    Mark MacDonald Feb 04, 2010
    Hey,
    that is awesome you have it working ! Keep an eye on it, those door sensor`s have a way of becoming loose/mis-aligned, hence the interior light stays on, the temp goes up and that`s why the alarm sound`s, Which bring`s a thought...why do we as people say an alarm is going off when it comes on,ha ha.
    Let me know if I can assist you in the future. Good luck.
    regard`s,
    macmarkus :)
No they dont seem to be turning off
Posted on Mar 19, 2015
Seal around door is not tight. there are no breaks in the seal but the door doesn't seal properly. you have to make sure that you close the door tightly and when you close the freezer door it causes the...
Is this unit new? Is it new to you? Has this problem just developed? I need the history to help you. If it is new, you have a year warranty. All units built today are as air tight as possible. When one door is opened and closed. The other door can pop open. To alleviate this issue the unit's front levelers must be adjusted to tilt the unit back slightly. The door or doors might still pop open but will close by themselves. If I can help you futher, let me know.
Mar 30, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Our frig won't go below 44 degrees. I've checked the coils and they are frost free. The freezer is working fine. Is it a thermostat problem?
It sounds like the condenser coil is dirty. That's the coil under or in back of the frig. Other than that check the door make sure it's closing and the door gasket is not ripped. It may be letting in warm air. If the t-stat clicks when you turn the dial it's working.
I hope this helps.
Aug 23, 2010 | GE GTS22KBP Top Freezer Refrigerator
Censor isn't working; temperature rising in frig (freezer ok)
Hi, do you think you could provide a model number. Some of those Samsung fridges have bad control boards at the back which could cause that problem OR the other possible fault could be the cabinet light sensor by the door hinge.( I'm going to assume it is this type based on the symptom you've described)Sooo...If you remove the hinge cover at the top you may find the receiving part of the sensor is misaligned or out of place completely which will prevent the semsor from detecting the door is closed, hence the interior light remains on and the temp rises and all sort's of unwanted side affect's. That is where I would start looking, but I don't even know if your unit has a push button door switch or the sensor style without a model number. However, based on several service calls for this exact problem in the past I'd say the chances are good it's the door close sensor if that applies to your model fridge. Hope that help's, let me know. Thanks for visiting fixya today. Good luck macmarkus :)
Dec 25, 2009 | Samsung Refrigerators
Door on my samsung frig' will creep open
The fridge needs to have a slight tilt back so the door will close with ease!! also check and clean the door gaskets and metal surface that the gasket touches when the door is closed because there is a magnet inside the gasket and it will make a nice tight seal if all the surfaces are clean.If the gasket is torn it should be replaced
Nov 06, 2009 | Refrigerators
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
I have a stanley garage door opener that won't close the door
the door beams are not working properly. Let me know what you find
Apr 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Freezer door opens just a tiny bit when i shut the fridge side anybody know how to fix this
to be honest with you, close the door more gently. there are air vents between the frig and the freezer, when you close the frig door its forcing air into the freezer which in turn forces the door open some. the air has to get out so thats what it does. i hear this complaint alot.
Nov 27, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Making Noise
The motor for the auger drive runs pretty slow (about 18 rpm), it could be the drive is running continuously (unless the door is open). Check that and let me know some more info, is the noise real loud, soft, etc. Can you feel anything vibrating or running when the door switch is pressed in?
Nov 05, 2006 | Amana ASD 2624 Side by Side Refrigerator
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
384 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
