Question about Maytag Freezers
My Maytag msd2756geb freezer is too cold.
My Maytag msd2756geb freezer stays at about -30 to -40F regardless of how warm I set the temp control. It sounds like it's always running. Frost forms around the door and at a point inside the fridge just above the top crisper door. The fridge temp control works fine. What might be the problem here?
  • Maytag Master
  • 43,501 Answers
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Posted on Feb 04, 2010
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Why doesn't the freezer stay cold if the temp gauges is set to cold(fridge)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | GE Freezers
Maytag Performa PTB2153GR making a clicking noise and food is thawing in freezer, fridge not staying cold
check no ice around pump unit. then try manual defrost both.no hot water. clean filters/drain holes.dry as best you can then switch on.
use thermometer to check temp -20c in freezer
Feb 07, 2010 | Freezers
I have a Frigidaire refrigerator with a top mount freezer, no ice maker. I have noticed that in really cold weather, the unit becomes less efficient, and in extreme cases, stuff in the freezer begins to...
When it gets very cold the gas (freon) in the refrigeration system shrinks....because the properties that make cold also work against you in this case...when the gas shrinks in volume it then does not work properly anymore...the hot gas does not turn back into a liquid but stays as a gas and because of that it does not cool when going through the expansion device...ie. cap tube or expansion valve. If you were to keep it in the cold all the time you could add a bit of charge to make it work, but then if you move it to warm or the weather warms... now you are over charged... just one of those "no win" deals...
They don't make these things to run in extreme environmental changes..they like it a consistent temp. all the time...
Heatman101
Jan 12, 2010 | Freezers
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Jun 10, 2008 | Kenmore Freezers
Open Questions:
Freezers Logo
282 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
