Question about Shaw Robert RS-9420 Thermostat
My Robertshaw 9600 displays 99 degrees and because it is satisfied, is not calling for heat. The temp is actually in the lo 60's and falling. I've tried battery replacement, but nothing changed. Other suggestions?
    Problem Solver:
  • 5 Answers
Hmm. I don't think it posted the first time around. So I'll try again.
There is a temperature sensing diode on the back side of this thermostat's circuit board. This diode may have failed or become disconnected.
I'd lean towards its having become disconnected, as I've been inside an example of this Robertshaw (originally Maple/Chase) 9600 thermostat and noticed that the soldering on this part was of poor quality. So if you have a soldering iron, and know how to use it, you could probably fix it.
I have a web page (just the facts, no ads, malware or fluff) that talks of some other common problems with this thermostat and how to fix them:
http://greyghost.mooo.com/maplechase9600/
Posted on Apr 03, 2010
Robertshaw thermostat 9600 lo battery
there are batteries in the thermostat that need replacing
Jun 28, 2013 | Heating & Cooling
My robertshaw thermostat works well in summer when using my Air conditioner. I have a heat pump. but in the winter the thermostat frequently displays "ER" during cold winter nights when the unit...
what it sounds like happening is the unit is realizing it is falling behind most thermostat s have a 3 degree deadband if they fall 3 degrees or more at a time after running for so long then it will bring on the emergency heat which is located in your inside unit... when it gets really colds and you see this you need to go outside and look is the outside unit still running and is it freezing up on you...also if running check the larger of two pipes make sure the large pipe is hot to touch...based on the description you have given the thermostat is calling for emergency heat but for some reason is not bringing it on or there is a problem with the emergency heat.... hope this helps out some
repost with any additional questions...
Jan 08, 2011 | Honeywell Electronic Programmable...
I have a RobertShaw 9600 and would like to set
go to there website and print the set up instructions, this should give you stsep by step set up.
Oct 27, 2009 | Heating & Cooling
My thermostat
Maple chase is the same I believe.Sounds like the thermostat is bad.I personally think the Honeywell 3000-4000 series thermostat are better.But the Maple should work!
Aug 18, 2009 | Honeywell Programmable Thermostat Heater
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Repace the tstat. Bad display. Make sure the batteries you put in were good First. Russ
Jul 25, 2009 | Heating & Cooling
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
Shaw Robert  RS-9420 Thermostat Logo
1,021 people viewed this question
Top Shaw Electrical Supplies Experts
obsteiner
Gil Shultz
Are you a Shaw Electrical Supply Expert? Answer questions, earn points and help others
