Question about Refrigerators
The refrigerator/freezer makes a rumble noise when it shuts off
  • 3,740 Answers
There are rubber isolation mounts under the compressor that get worn. What your hearing when the unit shuts off is the compressor shaking in the mount as the electricity to the run winding is shut off and the reverse torque twists the compressor in the mount to the point that it is hitting the mounting posts momentarily. Replacing the isolation mounts will stop the noise.
Posted on Feb 04, 2010
My side-by-sdie has started to emit an intermittent rumbling noise on the freezer side. The noise continues for a few minutes at a time, goes off for another few, then resumes again. Is there a...
It's common problem. Freezer fan hitting over ice formation behind freezer. It is due to non defrost problem.
Keep thermostat temp must be 5 degree and check timer and thermostat are working properly. Unplug your fridge and after all defrost icing, start again. If still noise behind freezer, check fan leaves are broken. If so replace it.thanks.
Jan 31, 2011 | Kenmore 53642 / 53644 Side by Side...
My refrigerator is over 5 years old. the refrigerator is making a rumbling noise and a beeping noise. i have switched it off hoping that it would reset itself.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | LG Refrigerators
Problems
Check to see if bottom freezer has not iced over, the back panel at rear of freezer has a small fan in it to circulate air and if the freezer coil in froozen /iced over the fan will hit the coil making loud noise.
try defrosting the freezer?
Jan 08, 2010 | Fisher and Paykel E522BLE Bottom Freezer...
Within the last month fridge started making a strange rumbling noise that lasts about 1-2 seconds. It occurs every hour or so. What is that and how can I fix it?
If the refrigerator is working ok,it may be the defrost drain pan vibrating when the compressor shuts off. You will need to see if it is out of position. Also, does this refer have an icemaker installed and if so is it working ok.
Dec 21, 2009 | Whirlpool ET8WTKXK Top Freezer...
Frig is driving me crazy---weird noise and no ice!!
That might be the fan. Making that noise, because fan stops when you open the freezer. The ice maker might be a totally diffrent problem. The solenoid may not be opening to let the water in, which is usually cause by a bad solenoid.
Nov 28, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
LG fridge/freezer rumbling/vibrating sound
Check your defrost components. The fan is hitting the frost buildup and will shut off when the door is opened so as to not circulate the warm air. The heater or the timer is not doing a proper defrost cycle.
Eric
Jun 24, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Fan keeps making loud rumbling noise
probably not tied in with each other, would change the fan and probably jump the water valve with 110 volts and see if you get water if not then change the water valve if so change the ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool ED2FHSS Side by Side...
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
GE side by side refrigerator is rumbling
Unit may be off level do to being wedged in so tight. No trick to rollers just carefully pull out unit.
Jan 31, 2008 | Refrigerators
Refrigerators Logo
411 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
