Question about GE WNSE6280BWW Top Load Washer
GE Washer will not spin...replaced lid switch..still have same problem
  • 129 Answers
Ck power plug behind control board ,has 1 year warranty, could be motor, or control board
Posted on Feb 04, 2010
Ge washer not draining or spinning
Im 99.9% sure its the lid switch. You can bypass the lid switch but for safety reasons I recommend replacing it.
Oct 27, 2012 | GE Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
GE Profile wont spin,why?
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wiring to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you replace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Thanks for using Fix-ya. A high rating would be appreciated for your free question :)
Jul 26, 2009 | GE Profile WPRE6100G Top Load Washer
My washer will not agitate after filling with water...
is the lid closed? if it is the it is the lid close safety switch you can by pass the switch but i would replace it if u do bypass unplug the machine its a safety thing. Tom
Jun 29, 2009 | GE WBSR3140DW Top Load Washer
GE® 3.5 Cu. Ft. King-size Capacity Washer will not spin/adgitate
I would check the lid switch. On many machines there is no motion at all if the lid is up. If the switch is bad it may not realize the lid is down and nothing will happen after the machine fills. You can try a web search for how to test or replace the lid switch for your specific model. There are also several appliance repair sites with how-to procedures as well as parts. It's not too difficult to change the switch yourself on most washers.
Jun 10, 2009 | GE Washing Machines
Washer starts to spin and quits after 10 seconds. It is like the spin timer is set to short or something.
place a screwdriver into the lid switch hole when the lid is up, timer on spin be careful as the tub will probably start to spin
if it does check lid switch and, lid for a broken lid pin that goes in the lid switch hole
Jun 08, 2009 | GE WBSR3140DW Top Load Washer
Washer will agitate but will not spin, could it ge lid switch ??
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
May 06, 2009 | GE WJSR2070B Top Load Washer
The start pause button will not work on my GE washer so washer will not come on
f the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 12, 2008 | GE Washing Machines
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
GE WNSE6280BWW Top Load Washer Logo
80 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
