Question about Roper MHE14XKB Microwave Oven
I have an under the counter Roper Microwave. The door was damaged by a grease fire and now the front glass is trying to fall out. I need a door for model #MHE14XMB-4. Any suggestions where to get it and how to install it.
I fixed the problem by buying a new microwave.  $200.00 for a repacement door is ludicrouis
Posted on Feb 04, 2010
LG door panel separating
DO NOT use this microwave in the current condition it is in- please! Although microwaves do not emit ionizing radiation, it does emit non-ionizing radiation and electromagnetic fields- and there is a lot of research studies being done possibly linking microwave exposure to cancer.
If your microwave is in that bad a shape, bring it to an authorized microwave repair shop or junk it and buy a new one.
For replacement parts, repair videos, and manuals: http://www.lg.com/us/support/parts-accessories
Jan 03, 2014 | LG Microwave Ovens
Should the plastic covering on front of kor-63mdc micro door be removed ,leaving a mesh front
NO! It provides vital protection for the metal mesh.
If it is damaged or gone, grease, food particles and moisture will accumulate on and damage the mesh, then microwave leakage is possible, which can result in a fire.
If the plastic is damaged or gone, it must be replaced. You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 18, 2010 | Daewoo Microwave Ovens
Roper microwave has broken glass in the door
Whatever you do don't use the microwave until you replace the door. You run the risk of possibly shattering the glass or being exposed to dangerous microwaves from the oven. Get on the Roper web site and find a replacement for the door. You never know there could be a recall for safety issues on your particular model.
May 02, 2010 | Microwave Ovens
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The glass on the microwave door on the outside has slipped down and there is no screws to take apart the door and fix the glass. Does this fall under the warranty? My 5 years is up on 12/01/09.
I would contact customer service (for Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here about the warranty and to find your nearest authorized servicer.
If not, it's pretty easy to fix this yourself.
There are probably broken tabs on the inner or outer door panel.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 26, 2009 | Maytag MMV1153A Microwave Oven
Front of microwave door scratched
3M 7447 pads get at auto parts store or more aggressive 180 grit sandpaper going with the grain of course. For daily cleaning use DeBruce Polish, it is non-toxic and odorless. DeBruce polish is also non-abrasive, also use DeBruce Polish on glass/ceramic cook tops. We get DeBruce Polish at debrucepolish.com
Feb 27, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave serial # xr2004675 superba heating
If the door seals tight & properly and the fine screen / mesh in between the door glass panels is not damaged, there should be no leakage.
But the risk remains that moisture and food particles will get into cracks and crevices and lead to arcing or rust, both of which can eventually damage the mesh.
What is the small curved piece that's falling out? Can you post a photo of it?
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 29, 2008 | Microwave Ovens
Glass front on door unglued
First: do not use this unit with the glass improperly installed. Often, these installations use double sided foam tape, available at any hardware store. Carefully remove the screws in the door being careful to catch the glass. Clean the area where the tape will go with glass cleaner or alcohol. Allow to dry and buff to remove oil and grease. Install the tape and glass. Reassemble.
Dec 18, 2007 | Maytag MMV1153A Microwave Oven
Can't remove under counter microwave.
I think there are only three very long bolts that can be used to attach this microwave to the cabinet floor or shelf. Grease, paint, varnish all can make the case stick to the cabinet. You might try running a putty knife or scraper around all the exposed edges keeping the top bolts in place so it will not fall down.
Aug 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
Roper MHE14XKB Microwave Oven Logo
109 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mark Cheong
Mark Cheong
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
