Question about Saeco Easy Espresso Machine
Blinking small red light.
After performing all the instructions in the book the small blinking light still stays on. This light should only blink when the water filter needs changing. I do not have a water filter on my unit. I descaled the unit, washed the processing unit, pushed on the red light for 15 seconds, stiill the unit keeps blinking. The unit still works but the blinking is annoying.
Vince
  • 3 more comments
  • Anonymous Apr 07, 2008
    I have the same issue. I've cleaned it and primed it. The unit still works fine, but I can't get the light to stop blinking.
  • Mr_Keldor Apr 13, 2008
    Same problem. The light is supposed to indicate only that the water filter needs changing. You are supposed to be able to get it to shut off by holding it in for 5 seconds. This does not work.
  • allora Jun 22, 2008
    I believe that you are pressing the wrong button. I fixed the problem by pressing the steam button and hold it for 5 seconds. Do not press the blinking button.
    allora6
  • Anonymous Mar 21, 2014
    All lights except on-off switch blink rapidly, including the water level light, and unit does not heat up; problem started suddenly
    All Lights blink rapidly except for the on off switch, including the the water level light and the unit does not heat up; started suddenly. Unit is about 5 to 6 years old.
I had that problem, it is the filetr reminder. I used Reverse Osmosis water so I dont use a =fileter, but the machine doesn't know that. If I recall the manual was wrong on which button to push an hold. I dont remember which was was right (could be the steam button). but one of them does make the light go out in about 5-10 sec.
Posted on Jun 22, 2008
It sounds like the machine needs to be primed. Turn it off, wait 5 minutes...without waiting for water to warm up... turn on hot water... it should prime the machine and the light should stop blinking...hope this helps
Posted on Mar 28, 2008
My Sony Bravia XBR 52in will not stay on and red light is blinking.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 23, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
Feb 19, 2011 | RIM BlackBerry Bold 9000 Smartphone
My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
follow this
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Jul 20, 2010 | Nintendo Video Game Consoles & Games
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
2006 Toyota Camry Security Light is blinking
Hi I'm litoshop if the security light stop blinking.then you deactived the alarm if your car has a factory alarm then the same light you see blinking look at it close and see if it's a switch push it in and put the key on and just turn on the dash light then turn it off the it should start blinking agian if it's not the light the look for a small red push botton and do the same as instructed above good luck. if this information has been useful please let us know thank you...
Aug 02, 2009 | 2000 Toyota Camry Solara
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
Saeco Easy Espresso Machine Logo
1,972 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
