Harmon Kardon Citation 22 amplifier is in protect mode
No power is being supplied for the tuner and CD player while in the protect mode.
    Brigadier General:
  • 8,546 Answers
Maybe there's a correlation to those devices being attached. Float the the amp so it has no cables to anything and figure out why it's going into protect mode. If it doesn't, start adding units until it does.
Posted on Feb 04, 2010
My Harman Kardon is AVR 151. It's not on. the power led is blinking. Sometimes it work correctly.i don't know what to do. please help!!!
Normally its a power supply that does that its protecting itself from further damage you will have to check the transformer or power supply in the unit normally it would be blown capacitor s
Sep 03, 2016 | Harmon Kardon Harman Kardon AVR1510...
On my Harmon Kardon 45 I push in the main power button and nothing happens
Hi
the device is in protect mode
1: speaker wires
2: Faulty power supply and usually this is the problem.
there is an internal power supply for +15 and -15 volts regulators.
on the main board .
need to be replaced
Good luck
Apr 15, 2015 | Harman Kardon Audio Players & Recorders
Volume decreases drasticly when playing fairly loud for 15-20 minutes
You're probably overdriving the amplifier, meaning the speakers are sucking up more power than the amplifier is capable of. When you turn it up loud it overheats and causes the system to go into a protect mode so it doesn't catch on fire (yes... it happens!). Make sure your system is capable of handling the power needs of your speakers. And don't burn your house down! I had a high-end Harmon-Kardon receiver burst into flames. It's a good thing I was standing next to it or my house would have been toast.
Dec 03, 2013 | Kenwood Kdc-x994 Car CD/ MP3 Player
Amplifier protection mode
use speakers withwith higher impedance, the sound is low but protected
Nov 03, 2012 | Harmon Kardon Harman Kardon HK990 2x150...
Harmon kardon hk3270 shuts off after only being on about 10 sec
Disconnect speakers and wires. Bad wiring or defective speakers may be loading the amp down and causing the protection circuits inside to disconnect (no sound). If the HK is heating up (beyond what you perceive as normal) with no wires or speakers connected then you have a problem requiring expert repair.
Oct 31, 2012 | Harmon Kardon Harman Kardon HK 3270 65W/CH...
Harmon Kardon CDR 2 no power
Check its fuse at the power supply section. If found opened,never insert an other one, till the fault has been rectified. Without any fault, the fuse won't go out. Try this to understand.
Apr 17, 2012 | Harman Kardon Audio Players & Recorders
My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Apr 02, 2012 | Harman Kardon AVR 2600
My Harmon kardon is stuck in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 19, 2011 | Harman Kardon Audio Players & Recorders
Harmon Kardon CDR26 unit shuts off
This is a problem in the power supply, various components go dry jointed.
Regards.
http://www.audiovisualservices.info/
Dec 11, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
308 people viewed this question
 Grubhead
Grubhead
