Model 556 F nergy saver - 2 yrs. - this yr ''shuts off'' binks I turn off then on to re-set. happens without power outages like every day now ???
  • 1,420 Answers
Turn the power off. Hold down the up arrow, down arrow and Economy buttons all at the same time and hold for three seconds. A series of lights will start blinking. Write down what you see. You may have to do this procedure again because the codes blink fast. Look up the codes in your owners manual or post the codes again on fixya and we can get you a starting point where to look. I suspect a flame failure because of a dirty flame rod or debris lodged in the burner.
Posted on Feb 05, 2010
Powers up then shuts down within 5 seconds? Power supply board? How much to repair?
MAYBE...A POWER SUPPLY BOARD REPAIR CAN COST YOU MAYBE $300-$500. OR MAYBE A FEW CAPACITORS..SMALL REPAIR. AFTER 13 YEARS, IF IT IS THE POWER BOARD, YOU MAY WANT TO INVEST TO A NEW MODEL.
Jan 31, 2014 | Panasonic PT-61HX40 61" Rear Projection...
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I have a rinnai energy saver 556f our power blew out and it knocked out all our appliances.i am trying to get my rinnai to stay lite but the pilot wont stay on.it goes on for about 3 seconds and then cuts...
Patrick,
Your 556 does not have a pilot light. When you try to start look into the window, you should see an arcing, this is the igniter. With a power outage there is no telling what may have happened. With only limited knowledge of a gas heater you should call a Rinnai service guy.
Good luck,
Tom
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Power shuts down and you cant turn the phone back on without removeing the batt then replaceing it. I have 2 new phone and it is happening to both.
i would contact your warranty center if you have had the phone less than a yr .. if it is a refurbished device warranty only covers through att for 90 days att warranty is 1-800-801-1101
Nov 18, 2009 | LG Vu CU920 Cellular Phone
I have a trouble code 11 on my Rinnai model 2532 water heater which indicates no ignition. I checked for gas supply by turning the furnace on which is approx. 1 ft. away, it works. The water heater is...
11 is a ignition failure code. Could be alot of things, I suggest calling a tech who has repaired these before. Pull the front cover off and have a helper turn on a hot water faucet. Look thru the viewing window to see if the unit is firing then going out. If not, clean out the water filter on the inlet side of the plumbing. You will need to turn off the water supply prior to cleaning it. If the unit fires but shuts off seconds after ignition, you may have a dirty or bad sensor. Call a proffessional at this point. Sorry
Oct 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Fellowes UPS 425AP
where the model u using is 4 to 5 yrs so as well the battery too normally the battery life spam is up to 2 to 3 yrs and slowly the battery efficenit start to wore off.. the cost of changing the battery it also not cheap. ard 200 to 300 dollar in the market. well if you hav the in attendtion to buy a new ups i suggest the brand is APC or liebert. i recommend u the APC it will be sua750i or Liebert gxt2-1500rt230 both model is user friendly and easy to configue. and it has a very effiecent of excute proper OS shut down when power sugre is occur. and this durablity it higer can maintain up to 5 yrs above. if u need asst on what kind of ups u refer pls mi know will try to help up... thkss
Mar 26, 2009 | Fellowes 99052 UPS 425VA Battery Backup...
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
Monitor blacks out after running for about 25 mins
Ok based on just the monitor turning off Lets try this,,
FOR WINDOWS XP
1.) Right click on your desktop
2.) Choose properties
3.) Click on the screen saver tab
4.) Click power
5.) Set The POWER SCHEME to Home/Office Desk
6.) Set the Turn Off monitor to Never
7.) Set the Turn Off hard disk and system Stand By to never
8.) Click apply then ok
9.) Repeat steps 1 - 3
10.) Set the wait time to 30 minutes
11.) Click Ok
12. Shut down and restart your system and wait 30 minutes to see if the monitor will shut off if it doesnt then Your good to go
If it does Then disable the screen saver.. and wait half hour to see what happens
POST BACK HERE AND TELL ME YOUR RESULTS OF THE ABOVE SO WE CAN TRY SOMETHING ELSE
Jan 16, 2008 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
