Question about Insignia IS-LCDTV32 32 in. Television
I have a insignia tv 32'' and dont came on just make noses
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you (or not) then please rate, thank you!i have a insignia tv 32'' and dont came on just - d823826.jpg
Posted on Feb 04, 2010
Insignia lcd tv
Hi em jay,
What do you mean? Your TV is too bright?
Jan 11, 2008 | Insignia IS-LCDTV32 32 in. Television
Synergy v remote code for insignia tv
Why don't you use the original one? Universal remotes provide just basic function and not full range.
Jan 22, 2018 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Insignia tv has a blue hue and green sparkles
make sure you dont have suround sound speaker on top of it or by it because the battery inside speakers will demagnatise your pitcher on tv if you do take them away then shot off tv then turn back on if you still have the problem your pixels is messed up in tv there will be no way fixing it.
Feb 27, 2011 | Insignia IS-LCDTV32 32 in. Television
Looking for tv stand for 32" Insignia flat screen
  1. 32 TV Stand- Ship Free1700+ TV Stands Arranged by Size, Price, Color & More. Lowest Costs!
    Exclusive Deals - Gift Certificates - Best Sellers -Entertainment Centers on Sale www.tvstands.com
  2. TV Stand For 32 InchGreat Selection of Brand TV Stands. Free Shipping on Your Order Today! Google Checkout thesimpletvstandstore.com
Jan 28, 2011 | Insignia NS-RTV32 32" TV
Do you sell stands for Insignia 32"
You should be able to purchase a stand for your Insignia TV here. Search for your TV model number.
Feb 14, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Used insignia 32 inch with DVD. want to reset
most manafactors codes are 1234 or 0000 or 5555 or 8888 you might have to put extra didget on EG 12345 -00000 - 55555 -88888 but if you changed it sorry dont know
Nov 10, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Insignia 32 HELLP
You can find parts for your TV here. If the power supply is an internal component, it is strongly recommended that it be installed by a TV repair professional.
Sep 30, 2009 | Insignia IS-LCDTV32 32 in. Television
I am trying to program my Insignia TV remote to my
Insignia TV's are made by Sansui....try one of their codes.
Sep 27, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
206 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
