Question about Goodman GMS90703BXA Heater
Sytem lockout in the goodman heather - Goodman GMS90703BXA Heater
  • 456 Answers
Turn the unit off, then back on this should reset the fault. If it does not
go into heating mode make sure thermostat is turned all the way up.
If nothing still doesnt happen then you need to make sure a breaker is not tripped.
If the furnace starts,then a hot surface ignitort should glow, if it doesnt
either it is cracked or the induced draft blower didnt come on. If it did glow and the burners lit and shut off, then the flame sensor is dirty and needs to be cleaned
Posted on Feb 04, 2010
Goodman heater lockout what does that mean
model no.?
any info on what caused it to go to lockout.?
may just be a limit switch needing manually reset. please disconnect from mains electrical supply first, before resetting.
Nov 21, 2014 | Heating & Cooling
System Lockout. Goodman Furnace. Please help
The thermocouple or the circuit board could at fault
Mar 21, 2013 | Heating & Cooling
What tod if there is system lockout
You can reset the system by turning the thermostat down and then back up in a minute or so or by turning the power to the unit totally off and then back on...
These things will reset most lockout conditions...
heatman101
Dec 10, 2010 | Goodman GDS80904BNA Open Flame Heater
What does it mean when my goodman furnace is flashing a red light and will not work.
It is in Lockout mode. Something has happened to make it go into lockout.
It could be an easy fix. Look of cobwebs in the tubing between the proving switch and the draft inducer motor. Look for air restrictions in the chimney flue. Rusty burners (if applicable). Tripped rollout switches. Some times there could be up to 2 roll out switches on the burner and another in the flue and 2 others in between stuff. . Most times it is a dirty flame sensor. Over the summer the flame sensor gets dusty and the sensitivity gets off. The control fails to FEEL the probe and locks out the gas valve. Most times the failure will be defines by the amount of blinks the red light emits. The sub panel has a guide on it that tells what the blinks mean.
Oct 19, 2010 | Goodman Heating & Cooling
Goodman model gmpn100-4 what does 3blinks on
Since most units do not have the same diagnosis,remove both cover panels and read diagnostics on the inside of the lower door.If it says flame sensor, clean it, with a dollar bill. Also, sometimes units will lockout. Shut power off for 10 or 15 minutes, and restart it. Good luck. If I had your phone number, we could do it a lot easier.
Feb 21, 2010 | Heating & Cooling
I have a 1997 goodman 3.5 ton outside gas, self igniting heater. the led beep is 1 then a 2 then a half second delay.
I am sure you have gotten this fixed by now. A 1 code is a general lockout meaning it tried to light 3 times and did not. A 2 code is for a stuck closed pressure switch. That pressure switch is normally open. If unit is off, and you remove the wires and using a multimeter, ohm across it, it should be open. If not, it needs to be replaced.
Dec 18, 2009 | Goodman GMS90703BXA Heater
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
Lock out on a goodman furnace
I have attached a link to download your owners manual troubleshooting guide. There is suggestions to follow coorisponding with the error codes.
http://www.dnmech.com/lit/IO-242.pdf
Oct 30, 2007 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
137 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
