Question about Kitchen Ranges
For some reason the oven cooks the food too fast, and it ends up burning. I tried to lower the temperature, but that didn't even work.
  • 80 Answers
Need thermostat calibrated
Posted on Feb 05, 2010
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Food in microwave is burning on edge and cold in the center
    you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
    Dec 29, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
    The bottom of the oven does not heat only the sides, is this the correct operation of the oven?
    ooking with a convection oven requires some adjustments, but may prove much easier and more rewarding in the long run. Because the heated air transfers heat more efficiently to cooking containers and exposed food surfaces, food will take less time to cook. Most recipes can be cooked for 25% shorter time, which ends up saving energy. The temperature at which food cooks may need to be lowered slightly on a trial and error basis.
    Oct 30, 2010 | Rival 18 Qt Roaster Oven with Buffet...
    How to change the lower element on a delonghi AD 699 toaster oven?
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Simpson Evolution 904 wall oven cooks very unevenly
    I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
    Sep 26, 2009 | Ovens
    Everything cooks to fast and usually burns, even though i set the oven at a lower than the recipe states
    The temperature control needs to be replace to get it
    back to its' original condition. E-mail back to me if otherwise.
    Sep 24, 2009 | Ovens
    Microwave doesn't heat food anymore
    Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
    The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
    There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
    Benjamin
    Apr 21, 2009 | Frigidaire PLMV168 Microwave Oven
    Cooks too hot/fast
    Hi Wendigo,
    Crock pots are not exact, they only have a "target" minimum temperature (to be sure they kill bacteria). It's possible you just have a relatively strong heating element.
    Also, remember that the boiling point of liquids changes considerably with your altitude, so if you're in a mountainous region you may be seeing "boiling" at a lower temperature than you expect.
    Nov 12, 2007 | Rival 3040-VG 4-Quart
    Concealed oven
    consealed bake means that the bake element on the bottom had a metal plate above it to make it easier to clean and to allow you to use the lower racks without burning the bottom of your food. To use, you want to make sure that the oven temperature that you set has been reached before putting in your food to be cooked. You also should put the racks one notch lower than you normally would. If you do this, you should have no problems with your food cooking unevenly.
    Jun 28, 2007 | Amana AOCS3040SS Electric Single Oven
    Kitchen Ranges Logo
    320 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
