Question about MagLite Mag-Lite& Flashlight
MAG-Lite flashlite with Battery removal problem
Have a MAG-Lite flashlite that has no evidence of damage or leakage, but the D-cell batteries will not come out. It is a 4 cell Dsize. Do I disassemble or what?
  • 2,926 Answers
Pull the cap off the end and wack it in your hand or a piece of wood, don't swing it like a baseball bat. Sometimes they get stuck in mine also, Not sure why, but a good wack gets the job done. Don't worry, the flashlight can take it.
Posted on Feb 04, 2010
I cannot get the one d cell battery left out of my 5 d cell mag flashlite I've done everything with no luck I don't want to destroy it with my frustration can someone help me please
Remove the lens end of the flashlight. Remove bulb. At the switch there is a small screw that should release the socket for the bulb and what ever else is left in the tube. If battery still stuck should be able to push it on through with what ever you have that will fit in the tube,.
Feb 06, 2016 | Camping, Backpacking & Hiking
CORROWDED BATTERIE STUCK IN FLASHLITE
Put on a pair of gloves. Then, using needle nose pliers grasp the battery and pull it out. If it's too far down to reach with needle nose, or if the corrosion has "welded" it to the inside of the flashlight, find a flat head screwdriver or stiff wire coat hanger or other tool/object that will reach and is stiff enough to pry the offending battery loose. Once it's broken free, turn it upside down and let the battery fall out on its own. The important thing now is, if you plan on using the flashlight again, cleaning out the inside thoroughly of all corrosive residue. This is particularly important on the metal battery/power contacts. A wire brush should suffice for the inside of the flashlight. Sand paper or file will work for the contacts. Attach to the tip of a screwdriver if you need to reach deep to get them clean. Baking soda will neutralize the battery acid. Finally, remember to recycle the offending battery not throw it out with the regular garbage.
Dec 12, 2013 | MagLite Mag-Lite& Flashlight
Alignment of 3 cell batteries
Positive terminal of battery goes in first. + . All other batteries follow in suit.
Apr 08, 2013 | MagLite Mag Instrument Mag Lite 2 "D"...
3 cell mag 1 battery came out the other are stuck. how do i get them out?
Hello, don't bang on the mag lite. Take a four inch deck screw and screw it into the battery one a time. Once the batteries are out. Mix up some water and baking soda.paste Take the soda paste and applied inside the tube around the corrosion areas. Rense with water and paste serveral times until the inisde of the tube is cleaan. Remove all components from mag lite be starting this operation. Wipe out with clean cloth and skake until al lwater is removed. GB ....stewbison
Aug 26, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
My mag lite led xl100 will not turn on, have fresh batteries installed
take the bottom piece off, remove the last battery and put a coating of petroleum jelly on the threads of the tube. Then take the bottom piece and run it all the way in and back off and back in 2 or 3 times. Then put a little more petroleum jelly on the threads and put the battery back in and the bottom piece. This should do it.
Apr 10, 2011 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I need bits for my 2 aa cell maglite. I live in durban
Packrat evidently stock spares for Mag Lites. They claim to take orders online and deliver as well. Try them on www.packrat.co.za
greetings to Durbs from Benoni.
Mar 09, 2011 | MagLite Mag-Lite& Flashlight
Bought a maglite 2-cell D today, put batteries in..no power at all.. help :)
make sure battery is good. Did you install batteries correctly? flat side (-) in first. Try adjusting the head where it screws on.turn in both directions. Last if this doesn`t work -return it for an exchange where you bought it..
hope your not in the dark..
Feb 25, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
How do the d batteries get placed in the
you need the small projecting going into the barrel first this is the positive end,the flat side of the battery is the negative end, all the batteries go in this way positive tip going in toward lamp connection,the cells are marked on the cell itself also
Dec 08, 2009 | MagLite Mag Instrument Mag Lite 2 "D"...
Battaries corroded in 2dcell lite. think I need to
i don't think that switch comes out so easily.... drive a screw into the end of the battery and yank it out...
Dec 06, 2009 | MagLite Mag Instrument Mag Lite 2 "D"...
Can't get them out to replace them
Unscrew the lens cover and remove the lens and reflector so you can see the top of the batteries. Remove the capoff the bottom of the light and then push the batteries out of the tube
Oct 31, 2009 | MagLite Mag Instrument Mag Lite 2 "D"...
MagLite Mag-Lite& Flashlight Logo
518 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
