Question about Nintendo Wii Fit - Balance Board + Game Console
I bought a used board and It did not come with directions.
I already down loaded the directions
Posted on Feb 05, 2010
Error message after installing used board in a HP Designjet T520
Some of these parts are not interchangeable due to the fact that important machine specific information is stored on the board. If you purchased the board directly from HP then return it and get them to replace it. If you bought it from a vendor as new return it they lied.
Mar 11, 2016 | HP Designjet T520 36-in ePrinter
My Asko washing machine model w6021 won't spin, At
It very well could be a programming issue. You would have to know what version of software each board had in it. Boards can be used in different machines where some functions just are not used as they are in the better models. There should be a stamp or something indicating the software version on the board, a chip, something. I would not run it like it is or something else is going to go.
May 19, 2012 | Washing Machines
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
I bought a Samsung 22"
This tv have problems with it tv Tuner signal board.That the board,where it take the incomming broadcasting signal cable and external devices inputs into it.Tv is still less than a year old,call for Samsung for a warrenty repair.Out of warrenty,tries websites like Shopjimmy.com,Ebay.com to buy a refurbuish tv Tuner signal board for the replacement.
Jan 30, 2011 | Televison & Video
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
Microwave goes on but does not heat
  • Magnetron is fried. Resistance between the magnetron terminals should be less than 3 ohms. Resistance from the magnetron terminal to ground should be infinite.
  • Fried HV capacitor. Use your ohm meter to test it.
  • Fried control board. If power is going to the board but not going off to the other components, the board is bad and needs to either be replaced or track down the bad connection (GE/Hotpoints).
  • HV Rectifier is shorted or open. Test forward and reverse bias with a megohmmeter. If continuity in both directions, rectifier is shorted, replace. If no continuity in either direction, rectifier is open, replace.
  • More help on testing specific components inside your microwave oven in this handy chart.
Aug 14, 2009 | Oster 4877 / 4878 / 6209 Toaster Oven with...
WHY WON'T MY COBY 610-4G work on a different computer?
maybe your cable you use has a defect just use another USB cable or esle you can directly plug your USB cable at the back of you CPU direct to the mother board
Jun 30, 2009 | Coby MP-610 MP3 Player
I have just bought an ASUS VW246H - has slight ghosting
I have just bought an ASUS VW246H - has slight ghosting? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
5E 0NC02 001 4H 0NC02 A01 ASUS 5E 0NC02 001 Power Supply Backlight...
Jun 16, 2009 | ASUS Computers & Internet
When ever I start my computer it directly goes to bios settings and it says *********** board frequency not set properly. I tried with every kind of frequency but it did not work out and also it takes...
You should check the BUS frequency as well, for the RAM. If the ram and mobo frequencies aren't set in a pair, but board won't work properly. Is there an option to set to factory defaults? I'd use that.
Jan 10, 2009 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Nintendo Wii Fit - Balance Board + Game Console Logo
29 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
