Question about Hitachi 61SDX01B 61" Rear Projection Television
Red bow on top and bottom of 61dx01b
Problem is with the colors not lining up the top from left to right has bowed red lines on the top of the screen and bowed red lines on the bottom of the screen....i tried the magic to allign the cross haires and it wouldnt move....is it the convergence....how do i fix it? is there a manual for it that i can get?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Feb 20, 2008
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
Bowed blue and red colors on t.v. akai 42in hdtv 1080i
You probably have a convergence issue. Since you did not include your make/model there's not a lot that we can do to help you. Try searching your model number with the word convergence in the search criteria.
Dec 06, 2009 | Televison & Video
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
Screen slooping and colors dont line up
Ur convergence it dead.U know how to solder right?Buy the convergence kit,use what in the kit.Tries these websites.Tv Repair World.com,Ebay.com.
Apr 04, 2009 | RCA R61WH76 61" HDTV
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Red lines
The top of my screen is pink and the color kind of bows down. The images are kind of distorted. Thanks for any help.
Sep 28, 2006 | Akai PT5598HD 55" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
153 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
