Question about GE 24 in. GSD3400G Built-in Dishwasher
The top tray wheel broke out of the track - GE 24 in. GSD3400G Built-in Dishwasher
  • 129 Answers
Track spread open use priers to adjust
Posted on Feb 05, 2010
Kenmore elite dishwasher top rack falling
The end of the track facing out has a plastic cap with a half circle molded into it. Slide the half circle sidways to release it from the track. Remove the basket. It will be obvious from that point how the adjusters are attached.
Nov 21, 2013 | Dishwashers
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
My thing broke that makes my drivers front window wind up even. what part do i need? Ihave power windows.
There is a plastic stay clip that attaches to that hole that guides the window in the track
May 08, 2012 | 1994 Oldsmobile Cutlass Ciera
Our Kenmore model 721.80833500 tray jumps off its track. This has progressively gotten worse over time and now the little end wheel on the rotating arm has broken off. The microwave still works and still...
Found 2 possible solutions on the net. (1) Check the engineering change at a Sears store. They reengineered the glass tray and the narrow plastic band the tray glides on. Get the new items from Sears. (2) Cut 1/4" out of the narrow plastic band the glass tray glides on. Possible solutions that look promising.
Dec 03, 2009 | Kenmore 80809 Microwave Oven
Tray won't open
I have the same problem, did they tell you what to do
Nov 27, 2008 | RJ Tech RJ-800DVX DVD Player
Dvd is not working, tv work just fine
My grandson's Lightning McQueen dvd player was acting up. The tray would come out about a 1/4 inch and then go back in. Once I got the tip on how to remove the case, I was able to access the dvd player. You must remove all four screws from the bottom of the unit. Carefully remove the smile from the front of the tray. After that you can slide the black tabs toward the front and get to the dvd player. To remove the dvd player, first carefully disconnect all the plugs from the back of the player, better to use a needle nose pliers than to try to grasp each connector with thumb and forefinger as you might inadvertantly pull a wire out of it's connector plug.. Now on each side of the player are two detent tabs. With two small pairs of pliers or needle nose pliers, pull the detents out a little on both sides and then the dvd player will slide out. It helps if you have a third hand to pull the player while you gently pull the detents out a bit. Once out, I removed the four bottom screws and the two top ones that are under the silver tape. Lift up the top from the rear and slide back a little then off. Once the metal cover is off, you must remove the four screws that hold the plastic part of the player to the metal base of the case. I discovered that the tray had jumped off it's track, or rather was probably forced off it's track by my grandson's pulling or pushing the tray too hard. If the tray comes out manually, then the small drive belt from the slide motor is probably suspect. Replace the belt. If the belt is ok, but the slide is off it's track, then carefully pull on the sides outboard from the tray, I was able to put the tray back on it's track. It's a small white pin or tab that rides inside a long track on one side of the tray. Leave the tray slide out while you are putting the four screws back in holding the player to the metal base. Put the metal top back on with the open end on the slide end and press is down onto the metal base. Replace the top two and four bottom screws. Before you slide the player back throught the detents, aim the extended slide throught the slot in the front of the case and snap the smile back on. If you don't have the slide out and it gets pushed back into the player, the slide will lock in and you won't be able to snap the smile back onto the front of the slide. After that you can pop the players notches back into the detents. Plug all connectors back into the back of the player. Align the tabs through the slots on the bottom of the unit and slide them back until the four screw holes line up. Put the four bottom screws back in. Put the cover back on allign it so that the two screws that go to the case on each side that were hidden by the fenders. Replace the top two screws and the two counter sunk screws where the video and audio inputs are on the back. Replace the wheels. Each wheel must go back on it's correct side, Line up the tab and the space in the back of the wheel and push the wheel back in on each side. Replace the three screws in the middle of each wheel and put each fake lug nut back into place. Use a small pair of pliers to gently squeeae the tabs of the lug nuts so that they will go in the slots easier. Plug the unit back in, turn on and after you select dvd, then you can press the open/close button for the tray to come out.
No parts were needed, as the one small drive belt that comes off the tray motor had not stretched or broke. Great patience is needed just for the removal and replacement of the back of the case.
Nov 16, 2008 | Disney DTD1363-CAR 13" TV/DVD
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Rotating ring/ Glide tray comes off the track -Elite Model 80803
Take your round glass tray and plastic three wheeled hoop to a local Sears store, open up the microwaves on display, find the one that is still using something similar, deftly trade out yours for theirs. The new wheeled plastic hoop wheels are slightly bigger and the glass tray raised guides are a bit longer, since the switch no problems like I had. Don't get caught. They do not have those parts for sale at the local Sears store.
Feb 20, 2008 | Kenmore 80809 Microwave Oven
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
Oct 20, 2007 | Kenmore 80803 Microwave Oven
GE 24 in. GSD3400G Built-in Dishwasher Logo
52 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
