Question about Breville Die Cast 800ESXL Espresso Machine
I havent used my breville die cast in abotu 6 months and now that ive turned it on the pump wont work, what can i do?
  • Breville Master
  • 1,711 Answers
The scale and dirt inside vibrating pump have dry out and keep the pump stuck. If your hands are capable you desasemble the pumb clean all the parts with a metal brush and put them back together 90% the pump will work perfect again. Their are 10% that the coil of the pump to be burn out then you will need a new pump
Posted on Feb 13, 2010
Where can you buy a pump? or any tutorial sites online you recommend on how to replace the Breville esp8xl pump?
Posted on Jun 04, 2010
Replace pump breville 800esxl
How to replace the thermostat in the breville 800esxl machine
Nov 07, 2013 | Breville Die Cast 800ESXL Espresso Machine
Problem with frothing unit. I bought my Die-Cast
It probably has a line clogged. It could be from backed up milk, but also could be the water you're using. Those things are finicky about have filtered water, especially because when the water heats up it can deposit calcium etc. onto the inner water lines. Only use store bought filtered water.
Oct 28, 2013 | Breville BES830XL Die-Cast Programmable...
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
Die Cast 800ESXL Espresso Machine: Breville 800 EXL espresso machine pump not working...
I have the same problem. I used my machine for one day to test it when I had it brought into Vietnam then packed it while our house was being built.
Now it won't pump water or produce steam.
To add insult to injury Breville advice "They don't give service manuals to the public"
May 17, 2010 | Breville Die Cast 800ESXL Espresso Machine
Although machine is turned off water pumps through to the over flow tray(power button is not pushed on )
Sounds like a check valve on the pump or the power switch is not operating properly, if off and pump is still working.
Mar 07, 2010 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine no suction but pump operates (makes noise). Cant find any obstructions in internal plumbing? Could the thermal plate be obstructed? I will try blasting it with...
I had the same problem. I opened up the back and disconnected the water hose from the spring loaded intake hose and put the hose directly into the tube and into the reservoir tank. Now it seems to **** the water in again. Not sure this is the best solution but it seems to work for now.
If someone has a better solution, I'd be happy to hear about it.
Dec 20, 2009 | Breville Die Cast 800ESXL Espresso Machine
Water tank vibrates loose
Try some of the expanding foam insulation in a can. Don't use too much as it expands considerably.
Sep 18, 2009 | Breville Die Cast 800ESXL Espresso Machine
Chrome on steam wand wearing off
Posted by compliance12@embarqmail.com
I have a Breville Die Cast 800ESXL and due to wrong cleaning process, I have to buy the steam wand. I tryed to find them in Breville.com but they does not have this part available for sale. Where can I buy this Steam Wand for my Breville Die Cast 800ESXL.
PLease let me know ASAP, at compliance12@embarqmail.com
Thanks
Oct 12, 2008 | Breville Die Cast 800ESXL Espresso Machine
Makes espresso, coffee, water, but will not steam
The pump has gone bad - through use. This is a common problem, and has to do with the "seals" that are in the pump. Since the pump generates high pressure and heat, over time, the seals will fail, and will be unable to generate enough pressure and heat to create steam. The only remedy is to have the pump replaced through the Breville Out of Warranty repair centers.
http://www.brevilleusa.com/support/service-centers.pdf
Dec 11, 2007 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
1,224 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
